zyhsu
javascript, text input
May 3, 2012 12:18 AM
Dear sir:
If I want to getTextString directly from keyboard input, not from textfield,
Can I do that?
thanks!
    May 3, 2012 5:06 AM   in reply to zyhsu
    You would need to store the characters that are being typed into a String variable. So you need to capture which keys are being used and add the characters for them to the string.
    May 3, 2012 6:04 AM   in reply to Ned Murphy
    Is this input inside Flash or just a standard HTML <input type="text" ..> situation?
    May 3, 2012 4:50 PM   in reply to zyhsu
    I cannot speak for what you do in C.  What you do in Actionscript depends on what version you are using, but for any version it boils down to having a listener assigned for keyboard input when you want keyboard input to be monitored.  In AS3 you would assign a listener for a KeyboardEvent and then have the event handler function determine which key was used and add it to the string.  Here is a very basic implementation to demonstrate (be sure to disable keyboard shortcuts in the player when you test it in Flash using Control -> Disable Keyboard Shortcuts).
    var str:String = "";
    stage.addEventListener(KeyboardEvent.KEY_UP, keyUsed);
    function keyUsed(evt:KeyboardEvent){
         str += String.fromCharCode(evt.charCode);
         trace(str);
