I am building my first website using Dreamweaver and I uploaded the site and when I go to it online, it comes up as the Parent Directory and my photos are gone. Please help:)
Did your web host give you instructions on where to upload your web site files?
Some hosts use public_html or www as the site root folder. If you have such a root folder on your server, it should go into your DW Remote Site settings.
Setting Up Local & Remote site folders (CS5 & CS5.5)
http://help.adobe.com/en_US/dreamweaver/cs/using/WS753df6af718a350a600 97e0f131686fa2b4-7ffe.html
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
I am not sure what local and remote site definition are exactly.
Local = your computer hard drive folder where you keep your site files
Remote = your web server.
In order to upload files to your web server, you must properly define your remote site details.
It might be worth contacting your host to confirm you have it right.
Nancy O.
www.allseasonroofing.com is my website
Get rid of the # signs in your links. From this:
<div id="menu">
<ul>
<li><a class="current"href="Website Template/index.html">HOME</a></li>
<li><a href="#services.html">SERVICES</a></li>
<li><a href="#gallery.html">GALLERY</a></li>
<li><a href="#Contactus.html">CONTACT US</a></li>
</ul>
To this:
<div id="menu">
<ul>
<li><a href="services.html">SERVICES</a></li>
<li><a href="gallery.html">GALLERY</a></li>
<li><a href="Contactus.html">CONTACT US</a></li>
</ul>
HINT FOR FUTURE: If you had posted a link to your site on May 2nd, you would have received an answer to your problem on May 2nd instead of May 7th.
Nancy O.
Your links are still not correct. If you set up your site properly, then use the put, get feature for file manipulation.
In DW to set up a site, on the file menu, site/new and under the "site" is where you pint it to the local folder on your computer
Then:
under Server, set up your ftp information for connecting to your server.
Once that is setup correctly, use the "put (put to the server)" and "get (get from the server)" feature to put files.
It will ask you if you want to put and get dependant files. What that does if you have added a pucture, and want to put the page with the picture, it will upload the picture also.
It is good practice to not use spaces in file names (page and picture).
You still need to remove the # sign on your <a href> tags linking your other pages as per Nancy's post above.
If you need a more detailed instuction for setting up your site, it has been hashed here many times so you can search.
Jim
Updated:
Your menu should be like below:
<li><a class="current"href="/index.html">HOME</a></li>
<li><a href="/services.html">SERVICES</a></li>
<li><a href="/gallery.html">GALLERY</a></li>
<li><a href="/contactus.html">CONTACT US</a></li>
Note that the contactus.html is all lower case, your previous it was Contactus.html which is not the same on your server.
Also, you header link is incorrect, you have:
<div id="header">
<h1><a href="Website Template/index.html">ALL SEASON ROOFING, INC.</a></h1>
but it should be:
<div id="header">
<h1><a href="/index.html">ALL SEASON ROOFING, INC.</a></h1>
