blakedodson.prg
Validation Code Confusion
May 3, 2012 2:07 PM
Tags: #acrobat_10_pro
Why doesn't this validation code work?  if(event.value == 135.31 | event.value == '') event.value = '';
It works if I don't use 135.31 and I only use 125, but I don't want it to show this particular dollar amount.  I don't know Java script at all, I copied most of this code from another forum.  Any ideas?  I can send the form I've created if that helps.
Blake Dodson
bdodson@prg.com
    May 3, 2012 2:19 PM   in reply to blakedodson.prg
    The second part of the if condition is not required. If the value is
    already blank, why reset it?
    Try this instead:
    if (event.value == "135.31") event.value = "";
    May 3, 2012 3:49 PM   in reply to blakedodson.prg
    Why are you using the Bitwise OR and not the Logical OR?
    The bitwise operators only process 32 bits of the the data string and not the entire floating point  number.
    I would also use the valueAsString property to test for the null string character, the value property sometimes treats the null character as a zero not a null string..
    if(event.value == 135.31 || event.valueAsString == '') event.value = '';
    May 4, 2012 5:46 AM   in reply to blakedodson.prg
    You can use the JS console to find out what's the exact value of the field.
    Just execute this code:
    this.getField("Field Name").valueAsString
    May 4, 2012 8:43 AM   in reply to blakedodson.prg
    if (this.getField("Field1").value == "0") event.value = "";
