eny erawati
missing tools panel
Apr 27, 2012 3:42 AM
the tools panel is missing and give me an 'internal error occured' warning window.
the ctrl + F2 doesnot change anything. i've tried the uninstall reinstall, but that doesnot help either.
the display was set to the highest setting, and i did not find any colapsed icon to expand or drag in.
and the property inspector is just blank.
can any body help?
thank you
    Apr 27, 2012 11:17 AM   in reply to eny erawati
    I don't know if it'll help or not, but you might want to check out this thread:
    http://forums.adobe.com/thread/994612?tstart=0
    Apr 27, 2012 3:31 PM   in reply to eny erawati
    In Firefox, try looking under Tools > Add-Ons to open the Add-ons Manager window, and then look under Extensions. At least that's where I think you'd find it—but you may not have it installed. I have to plead ignorance here: I have the Firebug extension (which I never really use), but not Flashbug or FlashFirebug, which I guess are extensions of Firebug that are geared towards Flash.
    http://blog.coursevector.com/flashbug
    http://www.o-minds.com/products/flashfirebug
    Again, this may not be the answer, but it seemed worth suggesting.
    May 3, 2012 10:36 PM   in reply to eny erawati
    Sorry to hear that! Problems like yours are a bit out of my area of expertise... Is your version of Fireworks recent enough that you still qualify for tech support from Adobe?
    Adobe Support and Customer Service
    800-833-6687
    Monday–Friday, 5am–7pm PST
    Fireworks Help: http://helpx.adobe.com/fireworks.html
    I'm wondering if the problem might be related to a bad preferences or user configuration file. Do you have another user account on your computer? If you did, I'd log into the other user account, open Fireworks and see if the same problem occurs. If the tools panel appeared, then I'd imagine that it's that type of issue. (Then again, your original post referred to an "internal error" warning dialog, so maybe not...). The following Adobe Help page provides some information on where to find the configuration and preference files:
    http://help.adobe.com/en_US/fireworks/cs/using/WS4c25cfbb1410b0021e63e 3d1152b00db4b-7ffc.html
    To avoid losing settings you'd rather preserve, I'd probably move any suspect files into a folder on your desktop, rather than trashing them. Then you could restore them later, if it turned out they were not causing the problem.
    Oh, wait! I just found a more detailed set of instructions for troubleshooting Fireworks preferences:
    http://helpx.adobe.com/fireworks/kb/restore-preferences-fireworks-cs5. html
    As for the Required folder, I'm not sure where that is... Is that application-specific? I have older versions of Fireworks and Photoshop, and they may not have the same folders that your version does.
    Hope this helps somehow!
