Simple Maths Tester
May 3, 2012 9:02 PM
Hey guys,
So I've been making a few simple maths programs to practice. I made this one as a simple addition/subtraction/multiplication/division tester. It tests addition/subtraction between 1-100 and the twelve times tables for multiplication and division.
I think it's just cos I scripted it a stupid way, but I'm having a few problems and I haven't been able to get it working. Firstly, I'm not entirely sure how to allow a minus sign in the answer box without seemingly upsetting everything. I thought it would just be:
answerBox.restrict = "0-9\\-\\";
or something similar but apparently that messes eveyrthing up when I try. Also, I used a simple 0 or 1 chance mechanic to decide whether or not it would be add/sub or mult/div, then I used the same mechanic to choose "add or sub", or "mult or div". The problem is I only ever get addition or subtraction, it never creates a multiplication or division question (even though I get roughyl 50/50 of add and sub, so the mechanic is working).
Also, it sometimes tells me an answer is wrong when it's right, like a simple addition of 10 + 3 and I give the answer as 13  and it says it's wrong.
I'm not getting ANY error messages or warnings in the compile errors section.
So basically my questions are : is this the best way to make this program? (I'm sure it isn't)
                                             : why won't it display the mult/div ones?
                                             : how do I allow a minus sign while restricting the text input into the answer box?
                                             : why does it sometimes tell me that certain correct answers are wrong?
Thanks, here is the code. Ignore the "emoticon face", that's just a movieclip picture that appears happy or angry whether they are right or wrong
package
    import flash.display.MovieClip
    import flash.events.MouseEvent
    public class Main extends MovieClip
        var numberOne = uint;
        var numberTwo = uint;
        var answer = int;
        var equationSign = String;
        var veracity = String;
        public function Main()
            emoticonFace.stop();
            answerBox.restrict = "0-9";
            questionButton.addEventListener(MouseEvent.CLICK, onQuestionButtonClick);
            answerButton.addEventListener(MouseEvent.CLICK, onAnswerButtonClick);
        function onQuestionButtonClick(event:MouseEvent):void
            if (Math.round(Math.random()) == 1)
                    equationSign = "addition";
                else
                    equationSign = "subtraction";
            else
                    equationSign = "multiplication";
                else
                    equationSign = "division";
            if (equationSign == "addition" || "subtraction")
                numberOne = (Math.ceil(Math.random() * 100))
                numberTwo = (Math.ceil(Math.random() * 100))
                firstNumber.text = numberOne.toString();
                secondNumber.text = numberTwo.toString();
                if (equationSign == "addition")
                    equationSymbol.text = "+";
                else if (equationSign == "subtraction")
                    equationSymbol.text = "-";
            else if (equationSign == "multiplication")
                numberOne = (Math.ceil(Math.random() * 12))
                numberTwo = (Math.ceil(Math.random() * 12))
                equationSymbol.text = "x";
            else if (equationSign == "division")
                numberOne = (numberTwo * (Math.ceil(Math.random() * 12)))
                equationSymbol.text = "/";
        function onAnswerButtonClick(event:MouseEvent):void
            answer = int(answerBox.text);
                if (answer == (numberOne + numberTwo))
                    correctIncorrect.text = "That is correct!";
                    emoticonFace.gotoAndStop(3);
                else
                    correctIncorrect.text = "That is incorrect!";
                    emoticonFace.gotoAndStop(2);
                if (answer == (numberOne - numberTwo))
                else
                if (answer == (numberOne * numberTwo))
                else
                if (answer == (numberOne / numberTwo))
                else
    May 4, 2012 1:25 AM   in reply to Bawlar
    change
            var answer = int;
    to
    private var numberOne: uint;
            private var numberTwo:uint;
            private var answer:int;
            private var equationSign:String;
            private var veracity:String;
    and
    to
    if (equationSign == "addition" || equationSign == "subtraction")
    and let me know if what probelms you still have
    May 4, 2012 1:29 AM   in reply to _spoboyle
    also change
    to
    answerBox.restrict = "0-9\\-";
    May 4, 2012 7:16 AM   in reply to Bawlar
    ahh sorry you didn't really
    I meant you to change
    to
    var numberOne:uint;
    the reason the private was there was because I mocked up an example in a class rather than on the timeline were i did need them. you don't and can safely delete them again
