ion
error handling inside cfc
May 3, 2012 10:16 AM
i have a cfgrid bound to a text field as well as a cfc
text field passes a value to cfc where it's being used as a parameter for a query . query can return zero records, when that happens, browser throws a json error
how can i trap this error inside the cfc and return a message to user? (without using a proxy)
thanks
    May 3, 2012 3:34 PM   in reply to ion
    sounds like if/else 101 to me.  What would you like to happen if 0 records are applied.
    May 4, 2012 1:19 PM   in reply to ion
    ion wrote:
    but i still didn't figure how to throw a "No records found" message for user
    <cffunction name="f" returntype="Any">
        <cftry>
        <cfquery name="myQuery">
        </cfquery>>
        <cfif myQuery.recordCount eq 0>
            <cfthrow message="Query returns no records">
            </cfif>
        <cfcatch type="any">
            <cfreturn cfcatch.message>
        </cfcatch>
        </cftry>>
    </cffunction>
    May 4, 2012 1:28 PM   in reply to BKBK
    Why are you going through the motions of raising an exception, only to catch it and then return the very message you threw in the first place?  Why don't you just return the message directly? What are you getting out of the try/throw/catch approach you're using here?
    It might be fair enough to raise an exception in situations in which there are no records, but you shouldn't catch it in th same context you throw it (it defeats the purpose of using an exception in the first place), just let the exception bubble up to the calling code, and let that code decide what to do with it.
    Adam
    May 4, 2012 2:08 PM   in reply to Adam Cameron.
    I agree, and hope Ion will note this. I have assumed he might want to run more business code in the catch and/or to manage the return. To have the exception percolate up the call stack, one could do something like
        </cfquery>
         </cfif>
    </cffunction>
    May 6, 2012 11:07 AM   in reply to ion
    ion wrote:
    looks like cfthrow inside a cfc behaves like the other tags i've tried, i can't really control it
    Not necessarily. See my previous example.
    However, note what Adam said. Throwing an exception is a powerful tool that should not be wasted on an example like this one. It would be preferable to just return the string "No records found".
    But, you may ask, what if the function is engaged in some other business which requires it to, for example, return an array. Then you could make the function's returntype a struct. The struct would then contain an array and a string! It goes like this
    <cffunction name="f" returntype="struct">
       <cfset var myReturnStruct = structNew()>
       <cfset myReturnStruct.values = arrayNew(1)>
       <cfset myReturnStruct.status = "">
        </cfquery>
           <cfset myReturnStruct.status = "Query returns no records">
            </cfif>
         <!--- Etc., etc., including business code that writes to the array myReturnStruct.values --->
         <cfreturn myReturnStruct>
    </cffunction>
    May 7, 2012 1:12 PM   in reply to ion
    there isn't any calling code, it's just a cfgrid bound to the cfc.
    Ah, sorry: I came into this late and didn't read the earlier posts.
    <cfgrid> has an onerror handler for when - I presume - a bind operation fails.  Does this not give you what you want?  The JS function can do anything, after all.
    Reading here:
    http://help.adobe.com/en_US/ColdFusion/9.0/Developing/WSc3ff6d0ea77859 461172e0811cbec22c24-7a01.html#WSc3ff6d0ea77859461172e0811cbec22c24-72 e0
    That said, I dunno how to send the message back from the server, but in this case perhaps you don't: you're just trying to pass back a hard-coded string if you get an error, so why not simply hard-code the message in the <cfgrid> code?
    I've never used this functionality before, so I'm pretty vague on how it works... if it sounds like it'll work, then perhaps google about a bit.  Or maybe someone else here is au fait with how it all comes together..?
    Adam
    May 7, 2012 1:27 PM   in reply to ion
    ion wrote:
    kind of half of a solution i found, is to attached a js function to the onLoad event of the grid, on the caller page, like:
    getTotalApps = function(){
    var isGrid = ColdFusion.Grid.getGridObject('myGrid');
    var isData = isGrid.getStore().totalLength;
    if (isData == 0) {alert("No records found"}
    however, this only works the first time page is loaded, not every time the grid changes, and since the onChange event is already occupied by the cfc, i can't put it there
    i was NEVER able to make <cfset ajaxonload("getTotalApps")> to work in ie8. if i put javascript within <head></head> tags, it renders a blank page with error "DOM is null or not an object"
    if i remove the <head>, function doesn't get executed
    Everything points to one of the simplest solutions possible, namely:
    <cffunction name="f" returntype="string">
    <cfset var message = "">
    </cfquery>
    <cfset message = "No records found">
    <cfelse>
    <cfset message = myQuery.recordCount & " record(s) found">
    </cfif>
    <cfreturn message>
    </cffunction>
    May 7, 2012 2:01 PM   in reply to ion
    ion wrote:
    BKBK, the cfc is bound to a grid so it must return a structure. you can't change returntype on the fly
    Please ignore. I posted that without realizing you already had an answer.
