Can't delete or move PDF
May 1, 2012 5:33 PM
Tags: #windows_7 #can't_delete #acrobat_9.5.1
I am using Acrobate Pro version 9.5.1 on a Windows 7 64 bit machine.
Once I have created a PDF, I find I am unable to move or delete the file. If I reboot the machine, I can delete or move the file, but as soon as I open a PDF, the problem is back until I reboot again.
It appears others have had the same problem, but I don't see any solutions. Does anyone have any suggestions or workarounds?
TIA,
Joe Parsons
  • David Kastendick
    Apr 7, 2010
    May 3, 2012 4:19 AM   in reply to jmparsons3
    Good day Joe,
    A few questions for you:
    • Where on your hard drive are you saving the file to?
    • Does the problem occur if you save to other locations on the hard drive?
    • Has this ever worked for you?  If so, what changed?
    Kind regards,
    David
    May 4, 2012 7:10 AM   in reply to jmparsons3
    Check that no parts of AA are left running after you close it. If AA still has a running part, it may not have released the file back to Windows. Of course, it may be an issue with the 64-bit OS which I am not very familiar with, other than it has caused a lot of different problems for folks.
    May 4, 2012 8:02 AM   in reply to jmparsons3
    What program do you use for moving or deleting the files?
    May 4, 2012 8:06 AM   in reply to jmparsons3
    Disable Preview in Windows Explorer or use a other File Manager Program.
    May 4, 2012 8:21 AM   in reply to jmparsons3
    I recommend using this program called "Unlocker", available here:
    http://www.emptyloop.com/unlocker/
    It allows you to find out which application has a "lock" on a file and even
    unlock it or kill the process.
    May 14, 2012 5:36 AM   in reply to jmparsons3
    You can check the process which has locked the file by using a utility "handle.exe", you can download it free from : http://technet.microsoft.com/en-us/sysinternals/bb896655
    Open this exe in command prompt and give the filename as parameter e.g
    C:\Documents and Settings\username\Desktop\ handle.exe "C:\Documents and Settings\username\Desktop\xyz.pdf"
    Now it will list the procees which has handle of the file. Try killing the process and then deleting or moving the file. But this is not the right solution to kill the process everytime. I am interesting in knowing that which process is locking the file. If possible, please share the file.
    Thanks.
