jackie2011
CAPTIVATE 3 SCORM COURSES DESIGNED FOR INTRANET DO NOT RUN THE SAME ON INTERNET
May 4, 2012 10:17 AM
Good Afternoon,
We have a client with about 700 elearning courses that were developed using Captivate 3 for their homegrown intranet-based LMS.  These same courses, which ran just fine on their old system now are not working quite as well on their new, internet-based SaaS LMS.  The new LMS is fully SCORM compliant.  Also, the new LMS company has many other clients running courses created with Captivate 3 working just fine.
Some of the issues we are seeing when uploading the files to the new LMS are:  bookmarking not working consistently if at all, auto-close not working as it did on the intranet-based LMS, Captivate close button doesn't work at all, button count being sent to the score area of XML.
I have seen posts regarding some of these issues and they all point to something the developer of the course needs to do.  The developer is saying "no" - they ran fine on their old system and both the developer and customer are looking to the new LMS provider to come up with a solution.
Any help would be greatly appreciated.
    May 5, 2012 3:24 AM   in reply to jackie2011
    Every LMS is different.  Even SCORM-compliant LMSs do some things differently.
    So the fact that the client's old LMS had no issues with the particular settings that these courses used, does not mean their next LMS must of necessity do likewise.  The reason there are so many options and settings in the SCORM area of Captivate is due to the fact that you usually have to experiment to find the combination of settings that work with a particular LMS.  In effect, you have to 'tune' the content for the LMS.
    So, like it or not, changing the LMS will definitely require some adjustments, and there are limitations to what the LMS vendor can do.
    I would suggest to your client that they try plugging their courses into SCORM Cloud to see what the diagnostics there show up.  If their content works perfectly on SCORM Cloud without issue, they'll have a better case to present to the LMS vendor than saying their "home grown" LMS handled it OK.
    May 7, 2012 6:44 AM   in reply to jackie2011
    Hi Jackie
    Two of those issues are likely caused by the same thing. Auto-close and the Exit button in the playbar. More information on that is offered at the link below.
    Click here to view
    My own guess on those issues is that the window presenting the course is now being opened in a different manner than it was in the other LMS.
    Cheers... Rick
    Helpful and Handy Links
    Captivate Wish Form/Bug Reporting Form
    Adobe Certified Captivate Training
    SorcerStone Blog
    Captivate eBooks
