If I install any version of flash higher than 11.1.102.63 it will not work on Windows 7 x64 under a LUA account. I have a very secure box using SRP policies. I've used the subinacl and reset_fp11.bat to no effect. Please advise.
I've got a few questions for you. Is a LUA account the same as a standard user account? If you create an admin account, does the player work properly? Can you elaborate on how your SRP policies might affect a Flash Player install? What browsers have you tried? If you haven't already, can you see if Flash works properly with Chrome (it's built in, so no need to install.) Finally, could you post a copy of your install log so we can see if anything is failing there?
Where do I find the Flash Player installation log on Windows?
Chris
Yes
Yes, I install it from the admin account and it works fine there.
Standard user accounts can not execute from directories they have permission to write to. No temp folders, desktop, etc.
IE 8 & 9. Both have the same reaction.
My testing:
The contents of C:\Windows\System32\Macromed\Flash\FlashInstall.log
=O====== M/11.2.202.235 2012-05-05+13-12-27.896 ========
0000 [I] 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_ActiveX. exe" -refreshIEElevationPolicies
=X====== M/11.2.202.235 2012-05-05+13-12-27.927 =========O====== M/11.2.202.235 2012-05-05+13-12-27.896 ========
=X====== M/11.2.202.235 2012-05-05+13-12-27.943 =========O====== M/11.2.202.235 2012-05-05+13-12-23.653 ========
0000 [W] 00001113 C:\Windows\system32\Macromed\Flash\\* 3
0001 [I] 00000010 "C:\Users\ADMINI~1\AppData\Local\Temp\{38334A5F-64C9-4F22-9451-F1B4DD C4BC5F}\InstallFlashPlayer.exe" -iv 6
0002 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0003 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0004 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0005 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0006 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0007 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0008 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0009 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0010 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_235.ocx
0011 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_ActiveX.e xe
0012 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_ActiveX.d ll
0013 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0014 [I] 00000011 1
0015 [I] 00000012
=X====== M/11.2.202.235 2012-05-05+13-12-49.596 ========
The fix is to add a hash entry for the dll file in the Software Restriction Policy editor ... see http://wilderssecurity.com/showthread.php?t=321105.
I would ask the Flash developers to consider honoring a proper LUA environment. It is very important that a directory a user can write too also not be an executable location. Thus the flash dll needs to write to %userprofile% directories and not copy executable code there. On our systems those locations will not be allowed to execute. Thank you.
Thank you for the heads up. I've forwarded this thread to our installer team for their review. I'd like to see this fixed, would you mind opening a bug on this at bugbase.adobe.com and post the bug URL back here and at wilderssecurity.com so that others affected can add their votes and comments?
My bug was closed because it was a duplicate. The original bug has closed as NotABug. The latest version of flash 11.3.3000.257 ... still has this bug. I know ... writing secure software is very hard.
https://bugbase.adobe.com/index.cfm?event=bug&id=3154246
https://bugbase.adobe.com/index.cfm?event=bug&id=3193896
