is there a script to delete frames?
May 4, 2012 9:31 AM
Hi
is there a script to delete frames on photos?
often i have to delete black or white frames or others colors , i 'm looking for a script to do it
thanks
cheers
    May 4, 2012 9:56 AM   in reply to mantralightroom
    Not unless you are talking about a frame as meaning a certain amout of pixels around an image (like a border). Do you have an example image?
    May 4, 2012 10:27 AM   in reply to mantralightroom
    I don't think you need to be uploading nude photos, just blur out the photo and leave the frame in tact to where I can get a visual of what you are describing as a "frame".
    May 4, 2012 10:39 AM   in reply to mantralightroom
    Just create an action that uses Image - Trim
    May 4, 2012 11:43 AM   in reply to mantralightroom
    Well, in cases like this, the only thing I can think of is to create an action which simply crops the canvas, but place a stop action on the script to allow you to manually enter how much you want to crop. But again, you would have to manually determine how many pixels you need to crop inwards.
    I thought you were going to show an image that had (say a 20 pixel white/black border) - then I would have said you could use the magic wand (or maybe "select color"), then create an action to reverse that selection then crop, but that wouldn't work with this photo. If all the images have the same thickness of border, you can create an action to just crop the image X amount of pixels. Do ALL your images have this exact border?
    May 4, 2012 11:48 AM   in reply to mantralightroom
    If there is no common value, then you would only be able to save a little time with creating an action that will physically perform a crop and maybe save the image. You would still have to manually define your crop region.
    May 4, 2012 11:57 AM   in reply to mantralightroom
    Just delete that particular reply.
    May 4, 2012 6:14 PM   in reply to mantralightroom
    You cannot edit or delete a post yourself once anyone has replied to it.
    But you can ask the hosts/moderators to delete it for you.
    May 7, 2012 1:52 AM   in reply to mantralightroom
    mantralightroom wrote:
    how can ask /find a moderator ?…
    You already did (right here) and it looks like a host has already deleted the image for you.
    May 7, 2012 3:39 AM   in reply to mantralightroom
    I gussing at you removed image… but what was the result of using… File/Automate/Crop and Straighten Photos
