few questions about cs6
May 4, 2012 7:26 AM
Hi
i have few questions about cs6
is there a way to let the ruler and straighten like cs5 ? i gave a look to my friend cs6 and cs6 ruler and straighten leave transparent image around the corner
and is there a way to set for each adjustament layer a size ? for example i like a big curve window but for example have a smaller level windows
thanks
cheers
    May 4, 2012 8:10 AM   in reply to mantralightroom
    Have you tried the Crop Tool and using that one’s Straighten function (from the Options Bar)?
    Are you talking about the Properties Panel (formerly Adjustments) or the Adjustment Dialogs?
  • Noel Carboni
    Dec 23, 2006
    May 4, 2012 9:37 AM   in reply to mantralightroom
    mantralightroom wrote:
    nope
    The feature is there, where Christoph described it, though I would have liked it if they'd left an option for the Ruler Tool button to allow people to add "and crop" as well.  But Adobe have confirmed they moved it out of there on purpose, presumably because new users would expect to crop their image using the Crop Tool, not the Ruler Tool.
    i would like to know if i can store the size of each dialog window
    You MUST be talking about the Properties panel, where adjustment layer info is shown, because the dialogs you get when you do things like Image - Adjust - Levels or Image - Adjust - Curves is not resizeable in any way I can see.  At least not on a PC.
    No, there's no special option that allows dialog sizes to be saved separately.  It's just one panel, and the size of the panel itself defines the size of the contents up to each of their max sizes.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 4, 2012 10:22 AM   in reply to mantralightroom
    Your English is just fine.
    But you were dragging the corner of the Properties panel...  You just didn't notice it.  Try it again, and this time look at the name in the tab.  The Properties panel is where all adjustments, such as Levels or Curves, are manipulated.  It is the only place those adjustments show up.
    The Properties panel is one and only one panel. Its contents just change. That's the way it works in Photoshop CS6.
    And no, I don't believe there's any way to get it to show in different sizes depending on what's displayed in there.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 4, 2012 11:49 AM   in reply to mantralightroom
    Yes, you can do that, but a little different way; click the little finger icon in the Properties panel first, then click on places in your image.  You can even then drag right in the image to move the curves.
    -Noel
    May 5, 2012 1:21 AM   in reply to mantralightroom
    no , i'm talking about for example the curve dialog window , i can enlarge using the corner and have a big window dialog
    Contradicting the obvious it seems …
    by the way , in cs6 there is no more the ability to add a point in the curve with ctrl and a click mouse with eyedropper selected,isn't it?
    Have you tried setting the Properties Panel’s fly out menu (when a Curves Layer is selected) to »Auto-Select Targeted Adjustment Tool«?
    With that setting when one selects a Curves Layer one can alt-click to set a point on the Curve in the Properties Panel.
