I used Dreamweaver and wrote a website with tabbed panels. It looked great in regular size screens, and I checked it across all kinds of browsers. But today I met with someone who has a wide screen. Some layers with text in them (in the logo) floated to the left, and on some pages the text also floated to the left so much that it covered the menu and the menu doesn't work anymore.
It looks terrible. Does anyone have an idea for fixing it? Here is the web address: www.mnsupportedliving.org
You ought to have a look at your page in the validator both for CSS and HTML
You have some coding problems. One thing the validator reports on your HTML is that you have and extra closing </div>. It points to your closing tag for the #contatiner but I suspect that you have a closing element somewhere in the page that tricks the validator into thinking that it is not open, if you see what I mean. Anyway, you need to scrutinise your opening and closing tags to find the one that's off.
Another obvious fault is that you have expressed id="mainContent" several times and you are only allowed one id per page. It's a unique element. Change the id to class="mainContent" and adjust your CSS accordingly.
There are a few problems in your CSS in the page. For instance, I think that you have an extra } in the middle somewhere and you also have a couple of lengths declared without a unit i.e. top: 300; should be top: 300px;
You should be cautious about using position: absolute. It's always best to try and do without it if you can. For instance, an element inside another might be positioned with margin to push it away from other elements. If you need to put elements side by side then turnt to float and add margin or padding to move the elements around a little. If those won't do, you can turn to position. It looks like you have used a template that uses position absolute so, you must have thought about that. If you add an element with position: absolute you need to give its container position: relative. Otherwise the position dimensions you give to the absolute positioned element will position to an higher element which could be the view port. That will cause elements to move when they are viewed on different screen sizes.
Martin
Absolute positioning (AP) is not your friend. You don't need it and shouldn't be using it for primary layouts.
Why? AP elements are removed from the normal document flow and positioned relative to the top left corner of the browser window. The problem is they don't move in relation to the page. This is why your AP elements look out of place when browser viewport is resized or page is zoomed out.
For best results, use default CSS positioning (static or none) along with margins, padding or floats for alignment. Your problems with drifting text will disappear.
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
Thank you very much!
The answer turned out to be very simple: I just added position:relative; to the CSS for the container. I didn’t need to do anything else.
Then I started working on all the little things that showed up when I validated.
Some things I couldn’t solve: Here are two of them:
If I don’t code it like this, the submenus don’t show up, but it doesn’t validate:
C:\wwroot\index.html
The tag: "li" doesn't have an attribute: "tabindex" in currently active versions.
160
You better check your site with increased text sizes. Looks to me like your header text gets chopped off.
As for your errors, don't worry about "tabindex." It's not a major issue.
<form> tags cannot be inside a <table> tag. Move your <form> to a table cell.
<table>
<tr>
<td><form>.... </form>
</td>
</tr>
</table>
ID names can be used only one time per page. You have used #mainContent multiple times. Change #mainContent (ID) to .mainContent (class) which can be used as often as you wish.
XHTML documents require all lowercase tags. Change POST to post.
Your input fields require an XHTML closure. Change this:
<input type="text" name="realname" size=40>
to this:
<input type="text" name="realname" size=40 />
HTML & CSS Tutorials - http://w3schools.com/
Nancy O.
