Multiple Choice Quiz Score
May 5, 2012 2:02 AM
Tags: #cs5 #flash_cs5 #actions
Hi all,
This is my first post here so, apologies if I break any unwritten rules, or say anything ridiculous, please bare with me.
So, I have created a multiple choice quiz using Flash CS5 as part of my multimedia project and wanted to know how (or if) I can incorporate a score system to the existing quiz.
I created the quiz using the timeline and layers. So for every question there are three layers;
Layer 1 - Question w/ four possible answers (only one is correct)
Layer 2 - Correct answer
Layer 3 - Incorrect answer
I am using buttons to navigate through the timeline.
What I would like to achieve is, at the end of the quiz, a score to be generated based on the questions they got right.
I hope I have included everything necessary.
Thanks for reading and the possible help.
    May 5, 2012 6:05 AM   in reply to Captain_Uppercut
    Create an actions layer that extends the full length of the timeline and in frame 1 create a score variable.  As you go along with the quiz, add/subtract value to that variable for right/wrong answers.  As long as that layer extends to the end, that variable is accessible to be changed, and at the end will equal whatever value it has accrued.
    May 5, 2012 10:22 AM   in reply to Captain_Uppercut
    That code will only have a chance of working if you are publishing for AS2.  In the first frame you want to declare the variable... there should be no need for any _root (AS2) reference...
    1st frame:   var total:Number = 0;
    subsequent frames....  total += 1   or    total -= 1 // add 1 or subtract 1
    note: total += 1  is the same as:  total = total + 1    (similar for -= )
    May 5, 2012 3:06 PM   in reply to Captain_Uppercut
    Create a textfield, give it an instance name, and assign the score to it as its text property...
    yourTextField.text = String(score);
Bookmarked By (1)
