GiladBarnea
5.1 Audio; I can see one definite speech channel. Can I cancel it out?
May 5, 2012 4:01 AM
Aspiring soundtrack composer here.
I've imported a movie with 5.1 audio. Here's a screenshot:
http://img100.imageshack.us/img100/8908/5channels.jpg
Can you see the channel with the red arrow?
It's by far the highest when there is only speech, it's about the same as others (or lower) when there is no speech. Is there a way to mute one channel? or mute all the others and leave the speech?
    May 5, 2012 6:53 AM   in reply to GiladBarnea
    I beleive that the standard mixes for 5.1 audio all involve a centre front speaker which carries all the major dialogue. Edit: larger mixes susch as 6.1, 7.1, 9.1 etc as well as dual sub arrangements (5.2, 7.2, 9.2) all carry this channel in the common arrangements, not seen any without it.
    What precisely is the end result you want with the audio? In effect muting this channel will cut all noticible dialogue, muting everything else will leave only speach.
    May 5, 2012 12:47 PM   in reply to GiladBarnea
    With 5.1 Source Material, you can use Break Out to Mono for that Clip, from the Project Panel, and then adjust the Center Channel, as needed.
    If I did not understand your question, then please ignore my comment.
    Good luck,
    Hunt
    May 5, 2012 3:33 PM   in reply to GiladBarnea
    If you have Adobe Audition, it has many ways in Multi-track Mode, to handle "karaoke," or the reverse.
    Some possible tutorial links are HERE.
    Good luck,
    Hunt
    May 5, 2012 4:20 PM   in reply to GiladBarnea
    If I could mute the music and keep the speech (and sound effects), that would be very helpful.
    You're much better off finding some local filmmakers who need a music track for their projects than trying to do this.
    May 6, 2012 7:40 AM   in reply to GiladBarnea
    Sounds like you have a plan and a workflow.
    Thank you for sharing.
    Hunt
