How to remove permanent watermark
Jul 26, 2010 8:24 PM
Hi:
I am a new Lightroom user. i can't seem to undo the permanent watermark that appears on my exported image. Tried as I may editing the watermark setting, I was not able to shut off the watermark appearance.
    Jul 26, 2010 11:33 PM   in reply to auzerais
    In the Export dialog, uncheck "Watermark":
    Beat Gossweiler
    Switzerland
    Jul 26, 2010 11:34 PM   in reply to auzerais
    Is this watermark on your original master image or only exported images? Can you see the watermark in Develop?
    If your watermark is only on exported images, you should disable it in the Export module.
    Same for other modules: Web, Slideshow. There's a checkbox in the respective module.
    Aug 26, 2010 6:53 AM   in reply to auzerais
    Good morning,
    I have tried but nothing works in either Library or Develop. Can't delete the watermark. Working with TIFF files.
    Please help.
    Regards
    Ray
    Aug 26, 2010 7:05 AM   in reply to raydeer
    May 5, 2012 10:37 AM   in reply to auzerais
    im having the same problem! ive done several different edits of the same shot and exported them with watermarks on them so that they couldnt be taken however, now that i sold an image i want to take the watermark off but cant!
    May 5, 2012 2:10 PM   in reply to shantastic85
    You work from your original and export without a watermark.
  • Rusty Sterling
    Feb 21, 2007
    May 6, 2012 12:06 AM   in reply to Rikk Flohr
    If you have already exported to jpeg or tiff with a watermark you simply cannot get rid of it without some manipulation. Just make sure that for future exports to jpeg or tiff you do as suggested by so many others above, uncheck the options that watermark the image.
    Like Rikk said, work from your original RAW image and export without a watermark.
