DanielSpellman
Losing masks when merging layers
May 3, 2012 7:49 PM
Hey guys,
So I have been trying to learn to be as non destructive as possible... one problem Ive recently had is that when I try to merge layers, I will lose the mask that was on one of the layers. How do I prevent this? :/
Cheers!!
  • Trevor Dennis
    May 24, 2010
    May 3, 2012 7:52 PM   in reply to DanielSpellman
    Hi Daniel
    The way I work is to always copy complex selections to a new layer (ctrl/cmd j).  That selection can then be quickly reloaded by Ctrl/Cmd clicking that layer.
    May 3, 2012 10:46 PM   in reply to DanielSpellman
    Well, naturally.
    Instead of merging you could try converting the batch to a Smart Object. Bloats file size but the Layer Masks would still be available in the SO.
  • Pierre Courtejoie
    Jan 11, 2006
    May 4, 2012 1:02 AM   in reply to Trevor Dennis
    Trevor, why not to a channel? Isn't it lighter? (but a layer might be faster to get to, according on how you set up your workspace)
  • Trevor Dennis
    May 24, 2010
    May 4, 2012 1:22 AM   in reply to Pierre Courtejoie
    That's fair comment Pierre, and I have Channels and Paths panels permanently available.   But can I create an Alpha mask without having to click on 'Save selection as Channel'?  Is there an existing keyboard shortcut?
  • Pierre Courtejoie
    Jan 11, 2006
    May 4, 2012 2:01 AM   in reply to Trevor Dennis
    I'm a CTRL+J person also, but I'm now using more and more the right-click everywhere possible, and in this case save selection. (refine edge is there too, save as path)
    I feel that the contextual menu are underused, and they are so fast to get to. (no need to lift the eyes from the image)
  • Trevor Dennis
    May 24, 2010
    May 4, 2012 2:31 AM   in reply to Pierre Courtejoie
    OK.  I had not thought of right clicking, and as you say, there are heaps of options, and they are obviously going to change with context.  I wonder if I can break the habbit though?
  • Trevor Dennis
    May 24, 2010
    May 5, 2012 4:05 AM   in reply to Trevor Dennis
    Pierre,  I've just got to add a comment here.  Since you mentioned right clicking, I have been trying it whenever I get a chance, and discovered a real wealth of useful shortcuts.  Thanks for the heads up.  You never stop learning with this app.
  • Noel Carboni
    Dec 23, 2006
    May 5, 2012 8:05 AM   in reply to Trevor Dennis
    One small note:  Every selection specifically is 8 bits/channel no matter what the document depth.  I say this because selection masks are always provided to plug-ins in 8 bits/channel format.
    So my point is that if you're editing deep (e.g., 16 bits/channel) image data, and whatever workflow you're using uses a selection as part of it, you will have quantized the data to 8 bits at some point.
    You can prove this to yourself if you're skeptical...  Make a radial pure grayscale gradient in a 16 bits/channel document.  Then control-click on one of the color channels to make it a selection, and Save the selection in a channel.  Now Copy the data from that channel and paste it over the original gradient as a new RGB layer.  Set it to Difference blending and greatly enhance the brightness of the differences...
    -Noel
    May 5, 2012 2:20 PM   in reply to Noel Carboni
    While "Selections" (the active dancing ants) are 8 bit, layer masks and channels are not limited to 8 bit when in a 16 bit image. The layer masks and channel retain their 16 bit editing. It's only when you make an active selection from a mask or channel that the selection is tunred into 8 bit. So, if you need to modify (feather or adjust) a selection in a 16 bit image, do so at the layer maks/channel stage before turning them into selections.
    It's been argued (by Chris Cox) that actual selections really only need 8 bit precision...if you can prove that's not true, I'm sure the engineers would rethink that. I've never been able to prove it...
  • Noel Carboni
    Dec 23, 2006
    May 5, 2012 2:36 PM   in reply to Jeff Schewe
    I just thought I'd mention it since some people do use the selection process as a stepping stone in their workflow to make things happen in their images, and the quantization might matter if the data is subsequently stressed a good bit.  As an example, such stressing might occur, for example, when digging very dim data out of astroimages.
    Nor have I ever had any problem with being able to select things at roughly 0.4% intervals.
    But at this point I wouldn't bet that Adobe could be convinced to embark on changing it for any reason, even if one showed a way that it was turning their images into hamburger.  The selection mask strikes me as being at the very heart and core of Photoshop - i.e., ingrained in the very oldest code - and stuff like that no doubt has accumulated a lot of implicit assumptions (e.g., byte addressing shortcuts) all throughout those 4 to 5 million lines of code you mentioned.
    -Noel
