I am using Windows 7 --64 bit and printing a PDF to dell 3115cn and can NOT print more than one copy of a PDF at a time. I have used adobe acrobat pro 8 and then went to reader x --same issues.
Any Ideas?
Gregg
Hi to all!
I have a similar issue using Adobe Reader X 10.0.1, 10.1.0, 10.1.2, when select File > Print > Page Handling: 1, click Printer Properties > Page Setup, specify eg. Copies : 5, it prints 1 copy only. Happen to a number of different printers, eg. HP, Epson, Xerox, Canon, Brother printer, etc. However, if you specify 5 copies inside Reader Print Dialog box, it prints 5 copies correctly.
It did not happen on Adobe Reader 8.1.3 and Reader 9.4.7. Meaning if you specify 5 copies inside printer properties, it prints exactly 5 copies. If you specify 5 copies inside Reader Print Dialog box, it also prints 5 copies correctly.
Anyone have any solutions or workarounds to solve this issue besides specifying Adobe Reader X : File>Print>Page Handling: 5 copies?
Thanks in advance!
This is most likely the mopier setting (yes it's a real setting) in the printer. It's usually enabled by default and is used so that a given app can send just one copy of a given job/page & then WIndows plus the printer take care of printing multple copies. With the combination of Adobe and particularly WIn 7, they get confused - especially if it's an older printer without much internal memory (most Adobe pages are memory intensive!)
Go to Devices & printers, right click the printer in question, choose printer properties, then select the device settings tab, scroll down to installable options & then disable mopier mode.
Best of Luck
