micfive
Encore BD finalizing problem
May 5, 2012 11:38 AM
My CS5 Encore program is not finalizing a BD disk at the end of the program. I am unable to duplicate the original BD in a new duplicator. I have had the computer checked, a BD disk analyzed by the equipment manufacture. The Problem is in the encore settings, which I am unable to supply a fix. If anyone out there can help me out, I would be forever thankful.
    May 5, 2012 1:53 PM   in reply to micfive
    i just create the disc to a disc folder and use img burn (yahoo/google it) to burn the disc. there are some quirks burning BD straight to disc it appears.
    May 5, 2012 2:24 PM   in reply to micfive
    http://www.imgburn.com/index.php?act=download  (send the author a PayPal donation if you like his program)
    May 5, 2012 7:14 PM   in reply to micfive
    Have you tried a preread on the disk in the duplicator?  That'll tell you if it can read things OK.
    May 6, 2012 8:17 AM   in reply to micfive
    >learning curve is a little steep when things go wrong
    Just FYI - the "authorcore" inside Encore is licensed from Sonic, and there have "always" been problems with the error messages out of Encore, due to the communication between the Sonic parts and the Encore overlay
    I only do DVD and the only problem I have ever had was failing to create a dual layer DVD, which is solved by using "Run as Administrator" with Encore, which is somehow different than simply running the computer on an Administrator account
    Even though I do not have any problems with Encore writing a DVD, I always use Imgburn since it gives me greater control over the writing parameters
    Try the Encore-->Folder-->Imgburn process to see how it works for you
    May 6, 2012 10:21 AM   in reply to micfive
    Yeah, I've never had a problem with DVD, but at the end of 2010 I converted to blu-ray and encore does have quirks with blu-ray discs. Never had much a problem with the imgburn workflow though.
    Sent from iPhone 4s
    May 6, 2012 10:31 AM   in reply to micfive
    Hopefully, now that Encore has been rewritten to be 64bit, any error message communication between the Sonic core and the Encore overlay will provide better messages to help with finding the problem
