Help! Colour banding graphics problem /posterization?
May 4, 2012 8:43 PM
Tags: #cs4 #color #graphics #card #gradients #banding #posterization
Hi.
I've been having a few problems lately with colour banding/gradients/posterization. I first noticed it 3 or 3 days ago in photoshop, and seem to have noticed it's mostly system wide. I ask her because you're all clever and I don't have a clue what to do next! So please help me!
Quoted from my thread somewhere else that I've had no luck with and was recomendded to try here...
Since yesterday whenever I'm using Photoshop and there is blurred edges/gradients etc, basically not solid colours, there is really noticeable sharp colour banding lines around it.
It's happened before and I've accidentally had it on 8-bit instead of 16-bit, but I've checked all that and it's on 16-bit.
I've googled it and the only suggestion was about duplicating the layer and blurring it then adding noise, but that didn't even work.
[EDIT] SINCE THEN I HAVE REALISED IT IS AFFECTING SYSTEM WIDE GRADIENTS AND COLOURS
My system is set to Highest 32-bit too. I changed it to 16-bit to see what happened and it made the banding 10 times worse.
An example of the problem
http://i50.tinypic.com/9hnof4.png
PostPosted: Thu May 03, 2012 7:32 pm    Post subject:Reply with quote Edit/Delete this post
It's supposed to be a smooth gradient. I didn't use the gradient tool, I used the brush tool with solid white and then smudged and blurred it like I always do.
That's a good point, and actually I did start it as an 8-bit originally (my photoshop has been starting as 8-bit, grayscale for a few weeks now and I don't know why) but then after I remembered and changed it to 16-bit, and noticed the banding, I closed that document and started a new one and changed it to 16-bit RGB when the pop-up for a new document came up.
The resolution is always 72pixels/inch, and the size 256x512, colour mode RGB.
In advanced it says colour profile Working RGB: sRGB IEC61966-2.1 which I have no clue what means, and I never usually click advanced so I don't know if that is usually that or different.
When I use the brush tool and blur and smudge it it's fine, with no banding. It's only when I lower the opacity of that layer, or use Hue/Saturation and Lightness to darken it so it's hardly visible that the banding appears.
I've just tried it again with a fresh new document and it's still the same. Even in 32-bit it's exactly the same.
It's done it before, and all I did was close and reopen Photoshop and it was all fine again, but this time it happened last night and since then I have restarted my computer, had it turned off for hours, and I've even tried it on gimp and it's the same.
Ruled out that it's my monitor, tried a different one that I know works perfectly and it's still the same.
I've double checked all drivers, and monitor profiles, and drivers for my monitor, and colour profiles, and colour management, my graphics card settings, device manager for problems with any hardware, and everythings coming back fine. Could it be that my graphics card is old and just needs replacing? I'm not good with which one to buy so would getting a new one the same be of any help? The computer is about 6 years old, and the only thing changed on it is the RAM and hard drive.
I don't really want to end up not using this computer anymore if it's a simple graphics card issue, I just don't know how to tell if it is.
The thread that is from is here if you want to see some suggestions I've already had.http://www.imvu.com/catalog/modules.php?op=modload&name=phpbb2&file=vi ewtopic.php&t=423942&postdays=0&postorder=asc&start=0
My username is 'Ao'  on there so that is me explaining the problem.
To add to that...
Here is another example of what is happening.
I'm thinking from all the answers I got from google its a graphics card problem. Only problem is all the updates are installed, and I can't find anywhere that sells my graphics card to buy a new one. So I need to know which graphics card will work with my system right now?
I've done some tests so you can see my system details. Im clueless with which one to buy so please help.
Here is the first system information....
Operating System new – server roles
System Model
Windows Vista Home Basic Service Pack 2 (build 6002)
Install Language: English (United States)
System Locale: English (United Kingdom)
Installed: 03/09/2011 15:55:03
GATEWAY E4214 200
System Serial Number: GCC7320001757
Processor a
Main Circuit Board b
3.45 gigahertz Intel Celeron D
16 kilobyte primary memory cache
512 kilobyte secondary memory cache
64-bit ready
Not hyper-threaded
Board: Intel Corporation D945GCCRG1 AAD86518-300
Serial Number: BTCR70500NBP
Bus Clock: 133 megahertz
BIOS: Intel Corp. CR94510J.15A.1015.2007.0712.1513 07/12/2007
new USB Storage Use in past 30 Days (mouse over last used for details)
new Hosted Virtual Machines (mouse over name for details)
Generic USB CF Reader -- drive 2, s/n 920321111113, rev 1.0105/05/2012 04:09:52
Generic USB MS Reader -- drive 4, s/n 920321111113, rev 1.0305/05/2012 04:09:52
Generic USB SD Reader -- drive 1, s/n 920321111113, rev 1.0005/05/2012 04:09:52
Generic USB SM Reader -- drive 3, s/n 920321111113, rev 1.0205/05/2012 04:09:52
HTC Android Phone, s/n HT1BMTR06733, rev 010021/04/2012 15:55:20*
HTC Android Phone, rev 010021/04/2012 15:48:53*
USB Mass Storage Device, s/n 81252009051921/04/2012 04:23:16*
* Possibly used again before the reboot following this time.
None discovered
Drives new – drive encryption
Memory Modules c,d
120.03 Gigabytes Usable Hard Drive Capacity
32.04 Gigabytes Hard Drive Free Space
ATAPI DVD W DH16W1P ATA Device [Optical drive]
Generic USB CF Reader USB Device [Hard drive] -- drive 2
Generic USB MS Reader USB Device [Hard drive] -- drive 4
Generic USB SD Reader USB Device [Hard drive] -- drive 1
Generic USB SM Reader USB Device [Hard drive] -- drive 3
WDC WD1200JS-00NCB1 [Hard drive] (120.03 GB) -- drive 0, s/n WD-WCANP1131697, rev 10.02E02, SMART Status: Healthy
2038 Megabytes Usable Installed Memory
Slot 'J6H1' has 1024 MB (serial number 0x683839C5)
Slot 'J6J1' has 1024 MB (serial number 0x6A397A46)
Local Drive Volumes new – volume encryption
c: (NTFS on drive 0)120.03 GB32.04 GB free
Network Drives
None discovered
Users (mouse over user name for details)
Printers
local user accountslast logon
Adam05/05/2012 04:13:02(admin)
Guest04/05/2012 16:15:14
local system accounts
Administrator11/04/2009 14:34:46(admin)
DISABLED Marks a disabled account;   LOCKED OUT Marks a locked account
Lexmark 3100 Serieson USB001
Microsoft XPS Document Writeron XPSPort:
Controllers
Display
ATA Channel 0 [Controller] (2x)
ATA Channel 1 [Controller]
Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0
Intel(R) 82945G Express Chipset Family [Display adapter]
LG L1917S [Monitor] (17.1"vis, s/n 11083, January 2006)
Bus Adapters
Multimedia
Microsoft iSCSI Initiator
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
Realtek High Definition Audio
Virus Protection [Back to Top]
Group Policies
AVG Internet Security 2011
None discovered
And here is my DxDiag...
System Information
Time of this report: 5/4/2012, 20:45:35
       Machine name: ADAM-PC
   Operating System: Windows Vista™ Home Basic (6.0, Build 6002) Service Pack 2 (6002.vistasp2_gdr.111025-0338)
           Language: English (Regional Setting: English)
System Manufacturer: GATEWAY
       System Model: E4214
               BIOS: Default System BIOS
          Processor: Intel(R) Celeron(R) D CPU 3.46GHz, ~3.5GHz
             Memory: 2036MB RAM
          Page File: 1829MB used, 2487MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
     DxDiag Version: 7.00.6002.18107 32bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name: Intel(R) 82945G Express Chipset Family
     Manufacturer: Intel Corporation
        Chip type: Intel(R) 82945G Express Chipset Family
         DAC type: Internal
       Device Key: Enum\PCI\VEN_8086&DEV_2772&SUBSYS_7201107B&REV_02
   Display Memory: 256 MB
Dedicated Memory: 0 MB
    Shared Memory: 256 MB
     Current Mode: 1280 x 1024 (32 bit) (60Hz)
          Monitor: Generic PnP Monitor
      Driver Name: igdumd32.dll
   Driver Version: 7.14.0010.1437 (English)
      DDI Version: 9Ex
   BGRA Supported: Yes
Driver Attributes: Final Retail
Driver Date/Size: 2/11/2008 19:36:08, 3301376 bytes
      WHQL Logo'd: Yes
  WHQL Date Stamp:
Device Identifier: {D7B78E66-6432-11CF-5676-0B52A3C2CA35}
        Vendor ID: 0x8086
        Device ID: 0x2772
        SubSys ID: 0x7201107B
      Revision ID: 0x0002
      Revision ID: 0x0002
      Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                   {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                   {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                   {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                   {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                   {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                   {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                   {AEDC1D5D-8546-440E-AAB2-B69FA725AF82}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_FieldAdaptive
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Enabled
Sound Devices
            Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0883&SUBSYS_107B7201&REV_1000
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: RTKVHDA.sys
         Driver Version: 6.00.0001.6526 (English)
            WHQL Logo'd: Yes
          Date and Size: 12/13/2011 19:27:30, 3921448 bytes
            Other Files:
        Driver Provider: Realtek Semiconductor Corp.
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
            Description: Stereo Mix (Realtek High Definition Audio)
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x1
           Format Flags: 0xFFFFF
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x27C8
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/11/2009 14:18:06, 196096 bytes
| Driver: usbd.sys, 1/21/2008 03:32:24, 5888 bytes
Gameport Devices
PS/2 Devices
+ Standard PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 1/21/2008 03:32:45, 54784 bytes
| Driver: kbdclass.sys, 1/21/2008 03:32:49, 35384 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ HID-compliant mouse
| Vendor/Product ID: 0x15D9, 0x0A4D
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 1/21/2008 03:32:45, 15872 bytes
| Driver: mouclass.sys, 1/21/2008 03:32:45, 34360 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 4/11/2009 14:18:05, 53224 bytes
| Driver: sermouse.sys, 1/21/2008 03:32:45, 19968 bytes
Disk & DVD/CD-ROM Drives
      Drive: C:
Free Space: 32.1 GB
Total Space: 114.5 GB
File System: NTFS
      Model: WDC WD1200JS-00NCB1 ATA Device
      Drive: D:
      Model: ATAPI DVD W  DH16W1P ATA Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 6.00.6002.18005 (English), 4/11/2009 14:18:06, 67072 bytes
System Devices
     Name: Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
Device ID: PCI\VEN_8086&DEV_27DF&SUBSYS_7201107B&REV_01\3&2ACF1E9&0&F9
   Driver: C:\Windows\system32\DRIVERS\intelide.sys, 6.00.6001.18000 (English), 1/21/2008 03:32:21, 17976 bytes
   Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.00.6002.18005 (English), 4/11/2009 14:18:06, 43496 bytes
   Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.00.6002.18005 (English), 4/11/2009 14:18:06, 19944 bytes
   Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.00.6002.18005 (English), 4/11/2009 14:18:06, 109032 bytes
     Name: Intel(R) 82801G (ICH7 Family) SMBus Controller - 27DA
Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_7201107B&REV_01\3&2ACF1E9&0&FB
   Driver: n/a
     Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_7201107B&REV_01\3&2ACF1E9&0&D8
   Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.00.6002.18005 (English), 4/11/2009 14:18:07, 561152 bytes
     Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D6
Device ID: PCI\VEN_8086&DEV_27D6&SUBSYS_27D68086&REV_01\3&2ACF1E9&0&E3
   Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.00.6002.18005 (English), 4/11/2009 14:18:06, 149480 bytes
     Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D4
Device ID: PCI\VEN_8086&DEV_27D4&SUBSYS_27D48086&REV_01\3&2ACF1E9&0&E2
     Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D0
Device ID: PCI\VEN_8086&DEV_27D0&SUBSYS_27D08086&REV_01\3&2ACF1E9&0&E0
     Name: Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_7201107B&REV_01\3&2ACF1E9&0&EF
   Driver: C:\Windows\system32\drivers\usbehci.sys, 6.00.6002.18005 (English), 4/11/2009 14:18:07, 39936 bytes
   Driver: C:\Windows\system32\drivers\usbport.sys, 6.00.6002.18005 (English), 4/11/2009 14:18:07, 226304 bytes
   Driver: C:\Windows\system32\drivers\usbhub.sys, 6.00.6002.18005 (English), 4/11/2009 14:18:06, 196096 bytes
   Driver: C:\Windows\system32\hccoin.dll, 6.00.6000.16386 (English), 11/2/2006 10:46:05, 8704 bytes
   Driver: C:\Windows\system32\hcrstco.dll, 6.00.6001.18000 (English), 1/21/2008 03:32:24, 15872 bytes
     Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_7201107B&REV_01\3&2ACF1E9&0&EB
   Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.00.6001.18000 (English), 1/21/2008 03:32:24, 23552 bytes
     Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_7201107B&REV_01\3&2ACF1E9&0&EA
     Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_7201107B&REV_01\3&2ACF1E9&0&E9
     Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_7201107B&REV_01\3&2ACF1E9&0&E8
     Name: Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0
Device ID: PCI\VEN_8086&DEV_27C0&SUBSYS_7201107B&REV_01\3&2ACF1E9&0&FA
     Name: Intel(R) 82801GB/GR (ICH7 Family) LPC Interface Controller - 27B8
Device ID: PCI\VEN_8086&DEV_27B8&SUBSYS_7201107B&REV_01\3&2ACF1E9&0&F8
   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.00.6001.18000 (English), 1/21/2008 03:32:22, 16440 bytes
     Name: Intel(R) 82945G Express Chipset Family
Device ID: PCI\VEN_8086&DEV_2772&SUBSYS_7201107B&REV_02\3&2ACF1E9&0&10
   Driver: C:\Windows\system32\DRIVERS\igdkmd32.sys, 7.14.0010.1437 (English), 2/11/2008 19:36:10, 2302976 bytes
   Driver: C:\Windows\system32\igdumd32.dll, 7.14.0010.1437 (English), 2/11/2008 19:36:08, 3301376 bytes
   Driver: C:\Windows\system32\iglhxs32.vp, 2/11/2008 21:06:46, 32848 bytes
   Driver: C:\Windows\system32\iglhxo32.vp, 2/11/2008 18:35:36, 2096 bytes
   Driver: C:\Windows\system32\iglhxc32.vp, 10/19/2006 03:10:57, 2096 bytes
   Driver: C:\Windows\system32\hccutils.dll, 7.14.0010.1437 (English), 2/11/2008 18:46:50, 106496 bytes
   Driver: C:\Windows\system32\igfxsrvc.dll, 7.14.0010.1437 (English), 2/11/2008 18:47:14, 48640 bytes
   Driver: C:\Windows\system32\igfxsrvc.exe, 7.14.0010.1437 (English), 2/11/2008 20:13:10, 256536 bytes
   Driver: C:\Windows\system32\igfxpph.dll, 7.14.0010.1437 (English), 2/11/2008 18:47:34, 204800 bytes
   Driver: C:\Windows\system32\igfxcpl.cpl, 7.14.0010.1437 (English), 2/11/2008 18:47:24, 122880 bytes
   Driver: C:\Windows\system32\igfxcfg.exe, 7.14.0010.1437 (English), 2/11/2008 20:13:04, 539160 bytes
   Driver: C:\Windows\system32\igfxdev.dll, 7.14.0010.1437 (English), 2/11/2008 18:46:44, 204800 bytes
   Driver: C:\Windows\system32\igfxdo.dll, 7.14.0010.1437 (English), 2/11/2008 18:46:58, 135168 bytes
   Driver: C:\Windows\system32\igfxtray.exe, 7.14.0010.1437 (English), 2/11/2008 20:13:12, 141848 bytes
   Driver: C:\Windows\system32\igfxzoom.exe, 7.14.0010.1437 (English), 2/11/2008 20:13:14, 170520 bytes
   Driver: C:\Windows\system32\hkcmd.exe, 7.14.0010.1437 (English), 2/11/2008 20:13:02, 166424 bytes
   Driver: C:\Windows\system32\igfxress.dll, 7.14.0010.1437 (English), 2/11/2008 18:46:32, 3293184 bytes
   Driver: C:\Windows\system32\igfxpers.exe, 7.14.0010.1437 (English), 2/11/2008 20:13:08, 133656 bytes
   Driver: C:\Windows\system32\igfxTMM.dll, 7.14.0010.1437 (English), 2/11/2008 18:48:00, 245760 bytes
   Driver: C:\Windows\system32\igfxext.exe, 7.14.0010.1437 (English), 2/11/2008 20:13:06, 170520 bytes
   Driver: C:\Windows\system32\igfxexps.dll, 7.14.0010.1437 (English), 2/11/2008 18:47:26, 24576 bytes
   Driver: C:\Windows\system32\oemdspif.dll, 7.14.0010.1437 (English), 2/11/2008 18:47:38, 69632 bytes
   Driver: C:\Windows\system32\igfxrara.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:14, 159744 bytes
   Driver: C:\Windows\system32\igfxrchs.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:14, 114688 bytes
   Driver: C:\Windows\system32\igfxrcht.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:14, 110592 bytes
   Driver: C:\Windows\system32\igfxrdan.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:16, 176128 bytes
   Driver: C:\Windows\system32\igfxrdeu.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:16, 192512 bytes
   Driver: C:\Windows\system32\igfxrenu.lrc, 7.14.0010.1437 (English), 2/11/2008 18:46:32, 172032 bytes
   Driver: C:\Windows\system32\igfxresp.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:16, 188416 bytes
   Driver: C:\Windows\system32\igfxrfin.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:16, 176128 bytes
   Driver: C:\Windows\system32\igfxrfra.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:18, 184320 bytes
   Driver: C:\Windows\system32\igfxrheb.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:18, 155648 bytes
   Driver: C:\Windows\system32\igfxrita.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:18, 188416 bytes
   Driver: C:\Windows\system32\igfxrjpn.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:18, 131072 bytes
   Driver: C:\Windows\system32\igfxrkor.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:20, 126976 bytes
   Driver: C:\Windows\system32\igfxrnld.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:20, 188416 bytes
   Driver: C:\Windows\system32\igfxrnor.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:20, 176128 bytes
   Driver: C:\Windows\system32\igfxrplk.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:20, 180224 bytes
   Driver: C:\Windows\system32\igfxrptb.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:20, 180224 bytes
   Driver: C:\Windows\system32\igfxrptg.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:20, 180224 bytes
   Driver: C:\Windows\system32\igfxrrus.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:22, 180224 bytes
   Driver: C:\Windows\system32\igfxrsky.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:22, 176128 bytes
   Driver: C:\Windows\system32\igfxrslv.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:22, 172032 bytes
   Driver: C:\Windows\system32\igfxrsve.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:22, 176128 bytes
   Driver: C:\Windows\system32\igfxrtha.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:22, 163840 bytes
   Driver: C:\Windows\system32\igfxrcsy.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:14, 176128 bytes
   Driver: C:\Windows\system32\igfxrell.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:16, 192512 bytes
   Driver: C:\Windows\system32\igfxrhun.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:18, 184320 bytes
   Driver: C:\Windows\system32\igfxrtrk.lrc, 7.14.0010.1437 (English), 2/11/2008 18:52:22, 172032 bytes
   Driver: C:\Windows\system32\ig4icd32.dll, 7.14.0010.1437 (English), 2/11/2008 19:01:30, 2420736 bytes
   Driver: C:\Windows\system32\ig4dev32.dll, 7.14.0010.1437 (English), 2/11/2008 19:01:44, 2174976 bytes
   Driver: C:\Windows\system32\igfxCoIn_v1437.dll, 2/11/2008 19:55:18, 147456 bytes
     Name: Intel(R) 945G/GZ/P/PL Processor to I/O Controller - 2770
Device ID: PCI\VEN_8086&DEV_2770&SUBSYS_7201107B&REV_02\3&2ACF1E9&0&00
   Driver: n/a
     Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_7201107B&REV_E1\3&2ACF1E9&0&F0
     Name: Intel(R) PRO/100 VE Network Connection
Device ID: PCI\VEN_8086&DEV_1094&SUBSYS_7201107B&REV_01\4&1535EDCF&0&40F0
   Driver: C:\Windows\system32\DRIVERS\e100b325.sys, 8.00.0044.0000 (English), 1/21/2008 03:32:24, 159744 bytes
     Name: PCI Soft Data Fax Modem with SmartCP
Device ID: PCI\VEN_14F1&DEV_2F40&SUBSYS_200014F1&REV_00\4&1535EDCF&0&28F0
   Driver: C:\Windows\SYSTEM32\DRIVERS\HSX_CNXT.sys, 7.67.0000.0000 (English), 6/20/2007 03:28:22, 660480 bytes
   Driver: C:\Windows\SYSTEM32\DRIVERS\HSXHWBS2.sys, 7.67.0000.0000 (English), 6/20/2007 03:28:38, 267264 bytes
   Driver: C:\Windows\SYSTEM32\DRIVERS\HSX_DPV.sys, 7.67.0000.0000 (English), 6/20/2007 03:29:56, 984064 bytes
   Driver: C:\Windows\SYSTEM32\DRIVERS\mdmxsdk.sys, 1.00.0002.0012 (English), 6/19/2006 06:26:58, 12672 bytes
   Driver: C:\Windows\SYSTEM32\DRIVERS\HSFProf.cty, 6/30/2007 14:38:38, 143829 bytes
   Driver: C:\Windows\SYSTEM32\DRIVERS\XAudio.sys, 1.00.0011.0000 (English), 6/29/2007 09:11:02, 8704 bytes
   Driver: C:\Windows\SYSTEM32\DRIVERS\XAudio.exe, 1.00.0011.0000 (English), 6/29/2007 09:11:16, 386560 bytes
   Driver: C:\Windows\system32\mdmxsdk.dll, 1.00.0002.0012 (English), 6/19/2006 06:26:50, 94208 bytes
   Driver: C:\Program Files\CONEXANT\CNXT_MODEM_PCI_HSF\UIU32m.exe, 4.00.0026.0000 (English), 6/26/2007 03:30:56, 790528 bytes
   Driver: C:\Windows\system32\UCI32M20.dll, 2.00.0020.0000 (English), 7/13/2007 04:42:40, 217088 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
MP3 Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
CoreVolume Filter,0x00000000,0,0,,
Full Screen Renderer,0x00200000,1,0,,6.06.6002.18533
Multiple File Output,0x00200000,2,2,WMM2FILT.dll,
WMT Black Frame Generator,0x00200000,1,1,WMM2FILT.dll,
WMT Import Filter,0x00200000,0,1,WMM2FILT.dll,
DV Muxer,0x00400000,0,0,,6.06.6001.18000
Color Space Converter,0x00400001,1,1,,6.06.6002.18533
WMT Interlacer,0x00200000,1,1,WMM2FILT.dll,
WM ASF Reader,0x00400000,0,0,,11.00.6001.7000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.6001.7000
AVI Splitter,0x00600000,1,1,,6.06.6002.18533
VGA 16 Color Ditherer,0x00400000,1,1,,6.06.6002.18533
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
WMT Format Conversion,0x00200000,1,1,WMM2FILT.dll,
9x8Resize,0x00200000,1,1,WMM2FILT.dll,
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.6002.18363
WMT Virtual Source,0x00200000,0,1,WMM2FILT.dll,
MJPEG Decompressor,0x00600000,1,1,,6.06.6002.18533
MPEG-I Stream Splitter,0x00600000,1,2,,6.06.6002.18533
SAMI (CC) Parser,0x00400000,1,1,,6.06.6002.18533
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.6001.18000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.6002.18363
WMT AudioAnalyzer,0x00200000,1,1,WMM2FILT.dll,
Stretch Video,0x00200000,1,1,WMM2FILT.dll,
Internal Script Command Renderer,0x00800001,1,0,,6.06.6002.18533
MPEG Audio Decoder,0x03680001,1,1,,6.06.6002.18533
DV Splitter,0x00600000,1,2,,6.06.6001.18000
CoreImgSrc,0x00000000,0,0,,
Video Mixing Renderer 9,0x00200000,1,0,,6.06.6002.18533
Frame Eater,0x00200000,1,1,WMM2FILT.dll,
CoreMovSrc,0x00000000,0,0,,
Allocator Fix,0x00200000,1,1,WMM2FILT.dll,
ACM Wrapper,0x00600000,1,1,,6.06.6002.18533
Video Renderer,0x00800001,1,0,,6.06.6002.18533
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.6002.18363
Capture ASF Writer,0x00200000,0,0,WMM2FILT.dll,
Line 21 Decoder,0x00600000,1,1,,6.06.6002.18533
Video Port Manager,0x00600000,2,1,,6.06.6002.18533
Video Renderer,0x00400000,1,0,,6.06.6002.18533
Bitmap Generate,0x00200000,1,1,WMM2FILT.dll,
Proxy Sink,0x00200000,1,0,WMM2FILT.dll,
Proxy Source,0x00200000,0,1,WMM2FILT.dll,
WM ASF Writer,0x00400000,0,0,,11.00.6001.7000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.00.6001.18000
WMT Sample Information Filter,0x00200000,1,1,WMM2FILT.dll,
File writer,0x00200000,1,0,,6.06.6001.18000
CoreCaption Filter,0x00000000,0,0,,
CoreNullXfrm Filter,0x00000000,0,0,,
WAV Dest,0x00000000,0,0,,
DVD Navigator,0x00200000,0,3,,6.06.6002.18533
WMT DV Extract,0x00200000,1,1,WMM2FILT.dll,
Overlay Mixer2,0x00200000,1,1,,6.06.6002.18533
AVI Draw,0x00600064,9,1,,6.06.6002.18533
WST Pager,0x00800000,1,1,WSTPager.ax,6.06.6001.18000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
Record Queue,0x00200000,1,1,WMM2FILT.dll,
DV Video Decoder,0x00800000,1,1,,6.06.6001.18000
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.6002.18005
Null Renderer,0x00200000,1,0,qedit.dll,6.06.6002.18005
WMT Log Filter,0x00200000,1,1,WMM2FILT.dll,
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.6002.18496
WMT Virtual Renderer,0x00200000,1,0,WMM2FILT.dll,
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.6002.18363
Smart Tee,0x00200000,1,2,,6.06.6001.18000
Overlay Mixer,0x00200000,0,0,,6.06.6002.18533
AVI Decompressor,0x00600000,1,1,,6.06.6002.18533
WMT MuxDeMux Filter,0x00200000,0,0,WMM2FILT.dll,
AVI/WAV File Source,0x00400000,0,2,,6.06.6002.18533
WMT Volume,0x00200000,1,1,WMM2FILT.dll,
Wave Parser,0x00400000,1,1,,6.06.6002.18533
MIDI Parser,0x00400000,1,1,,6.06.6002.18533
Multi-file Parser,0x00400000,1,1,,6.06.6002.18533
File stream renderer,0x00400000,1,1,,6.06.6002.18533
WMT VIH2 Fix,0x00200000,1,1,WMM2FILT.dll,
AVI Mux,0x00200000,1,0,,6.06.6001.18000
Line 21 Decoder 2,0x00600002,1,1,,6.06.6002.18533
File Source (Async.),0x00400000,0,1,,6.06.6002.18533
File Source (URL),0x00400000,0,1,,6.06.6002.18533
AudioRecorder WAV Dest,0x00200000,0,0,,6.00.6001.18000
AudioRecorder Wave Form,0x00200000,0,0,,6.00.6001.18000
SoundRecorder Null Renderer,0x00200000,0,0,,6.00.6001.18000
Infinite Pin Tee Filter,0x00200000,1,1,,6.06.6001.18000
WMT Switch Filter,0x00200000,1,1,WMM2FILT.dll,
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.00.6002.18005
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,WMM2FILT.dll,
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.6002.18496
MPEG Video Decoder,0x40000001,1,1,,6.06.6002.18533
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,6.00.6001.18000
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,,6.06.6001.18000
MJPEG Compressor,0x00200000,0,0,,6.06.6002.18533
Cinepak Codec by Radius,0x00200000,1,1,,6.06.6001.18000
Logitech Video (I420),0x00200000,1,1,,6.06.6001.18000
Intel IYUV codec,0x00200000,1,1,,6.06.6001.18000
Microsoft RLE,0x00200000,1,1,,6.06.6001.18000
Microsoft Video 1,0x00200000,1,1,,6.06.6001.18000
VP60® Simple Profile ,0x00200000,1,1,,6.06.6001.18000
VP61® Advanced Profile,0x00200000,1,1,,6.06.6001.18000
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,,6.06.6002.18533
Microsoft ADPCM,0x00200000,1,1,,6.06.6002.18533
GSM 6.10,0x00200000,1,1,,6.06.6002.18533
Messenger Audio Codec,0x00200000,1,1,,6.06.6002.18533
CCITT A-Law,0x00200000,1,1,,6.06.6002.18533
CCITT u-Law,0x00200000,1,1,,6.06.6002.18533
MPEG Layer-3,0x00200000,1,1,,6.06.6002.18533
Audio Capture Sources:
Stereo Mix (Realtek High Defini,0x00200000,0,0,,6.06.6001.18000
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,,6.06.6002.18533
Microsoft GS Wavetable Synth,0x00200000,1,0,,6.06.6002.18533
WDM Streaming Capture Devices:
Realtek HD Audio Line input,0x00200000,1,1,,6.00.6001.18000
Realtek HD Audio Mic input,0x00200000,1,1,,6.00.6001.18000
Realtek HD Audio Stereo input,0x00200000,1,1,,6.00.6001.18000
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,,6.00.6001.18000
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.6002.18005
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.6002.18496
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.6002.18496
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,EncDec.dll,6.06.6002.18528
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.6002.18528
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.6002.18528
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definiti,0x00200000,1,0,,6.06.6002.18533
Default DirectSound Device,0x00800000,1,0,,6.06.6002.18533
Default WaveOut Device,0x00200000,1,0,,6.06.6002.18533
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,,6.06.6002.18533
Please help me? I need to know whether or not there is something I might have missed that I can try, and/or which graphics card I need to buy that is going to work with my system as it is now.
Thank you all so much in advance! Really hoping to get this problem fixed, as I use Photoshop daily for work as a 3D texturer, and have already been without for 3 days now which is a liftetime in texturing!
Edit to add: I use Photoshop CS4 version 11.something, and I've installed the latest patch.
Replies 1 2 Previous Next
    May 4, 2012 9:00 PM   in reply to adambrandrick111
    Do a test on a 2000x2000 pixel image and see if banding still occurs.
    On an image thats 256 x 256px would be one color per pixel. So a small area on that same image, would not have enough shades to create a smooth gradient.
    Thats my theory anyway. I beleive 16 bit image makes my point moot, but hey maybe?....
  • Noel Carboni
    Dec 23, 2006
    May 5, 2012 10:31 AM   in reply to adambrandrick111
    What color profile is associated with your monitor?
    Have you used a device or process to calibrate/profile your monitor's characteristics?
    I skimmed through all of the info you posted above and I don't see information pertaining to these questions.
    Quite often the system automatically installs a profile for a particular monitor that comes from the monitor manufacturer, and amazingly these often seem to be quite flawed.  At best, they're likely not to describe a particular monitor connected to a particular video card very well.  At worst they can utterly botch the display from color managed applications (like Photoshop).
    The profile is associated with the monitor at the operating system level.  Click Start and type color management in the search box to get to the pertinent dialogs.
    You should know that the images in the screen grabs you posted above don't seem to be flawed as displayed on my monitor, at least I'm not seeing any obvious banding.  Do you see any banding in this image?  It's perfectly smooth here.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 5, 2012 12:50 PM   in reply to adambrandrick111
    Yes, your images all appear perfectly smooth to me here.
    Try this as a test to confirm or eliminate that the problem is with the monitor profile you are using:
    1.  Go into your OS Color-Management dialog and choose the Devices tab.
    2.  Ensure your monitor is selected in the Device field at the top.
    2.  Check the [  ] Use my settings for this device box.
    3.  Click the [ Add.. ] button.
    4.  Scroll down as needed to the profile named sRGB IEC61966-2.1, select it, and hit the [OK] button.
    5.  With that sRGB profile selected, hit the [ Set as Default Profile ] button.
    6.  Log out and back into Windows to make sure everything is aware of the change.
    7.  Open an image in Photoshop and see if it's still posterized/banded.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 5, 2012 1:29 PM   in reply to adambrandrick111
    Photoshop's color settings and those you are manipulating in the OS Color Management dialog are related but not the same thing.
    Did you try EXACTLY what I said in post 6 above before?  If not, please do so.  It will take only a minute.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 5, 2012 1:52 PM   in reply to adambrandrick111
    Sorry to make you jump through that hoop, but now we can say that the problem is not a monitor profile issue, even though it sounds very much like a bad monitor profile.
    It's possible it's a hardware problem...  Have you tried checking your cable connections, and even swapping in a different cable between computer and monitor?
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 5, 2012 1:54 PM   in reply to Noel Carboni
    Another thing to try, if you haven't already, is to go into Photoshop's Edit - Preferences - Performance dialog, disable the [ ] OpenGL Drawing setting, and close and reopen Photoshop and retest.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 5, 2012 3:02 PM   in reply to adambrandrick111
    Did you say you are seeing the problems from apps other than Photoshop (e.g., Internet Explorer)?
    If so that wouild imply something wrong in the monitor or video card.
    You've said you've already tried a different monitor and cable...  Process of elimination:  Do you have a video card you can try (assuming your GPU being Intel implies it's on the motherboard)?  You might find that a new video card, something like an ATI Radeon HD 6670, might breathe new life into your system anyway.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 6, 2012 4:32 AM   in reply to adambrandrick111
    Does your system have the ability to take a (pretty standard) PCIe x16 card?
    The video card I mentioned has a fairly low power supply draw, which can be important if your computer has only a basic power supply.
    Edit:  There are some 6670s listed on the web page you linked-to.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 6, 2012 4:48 AM   in reply to adambrandrick111
    Did you get a manual with your computer?  If not, or you no longer have it, you could search for the model online.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 6, 2012 4:52 AM   in reply to adambrandrick111
    If I've not taken a wrong turn in doing a quick search myself, this may be your motherboard:
    http://www.e4allupgraders.info/dir1/motherboards/socket775/D945GCCR.sh tml
    If that's accurate, you should definitely check my work to be sure I didn't get it wrong, then you have one PCI Express (PCIe) x16 expansion slot.
    -Noel
    May 6, 2012 6:22 AM   in reply to adambrandrick111
    I didn't read the whole thread and I may be missing something but I gather the problem could be incapable monitor and getting a better video card may not fix the problem. It also could be bad monitor hardware settings like increased contrast.
  • Noel Carboni
    Dec 23, 2006
    May 6, 2012 6:59 AM   in reply to adambrandrick111
    The choice of which graphics card to buy is yours.  The 6670 is the one I recommend when asked, because it's both pretty fast and draws only minimal power from the computer's power supply.  That latter consideration is important.
    For Photoshop use I usually advise people to try to choose a card that scores at least 500, ideally more than 1000 on this benchmark:
    http://www.videocardbenchmark.net/
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 6, 2012 7:13 AM   in reply to adambrandrick111
    According to ATI they recommend 400W, and they're being overly conservative I think with that requirement.  The card itself draws about 70W as I recall.
    The x670 line of ATI cards are low power users while still delivering very good performance.  In fact, these cards don't even need a separate power connector from the power supply.  I have the 6670's predecessor myself, the 5670, driving two 1600 x 1200 monitors.
    You would be adding the ATI card's power draw to the computer, though you might get a little back when the onboard display adapter is disabled in the BIOS.  If you have a lot of extra hardware already in there - e.g. more disk drives or something - you might find it could tax a 300W power supply.  But if that card is the only thing added to your system it will most likely be fine.  Another option is to also upgrade the power supply.  Such things are available from local high tech stores.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 6, 2012 7:14 AM   in reply to adambrandrick111
    Just one other thing...  Your computer overall is getting a bit old and is kind of underpowered for graphics work.  Maybe the time is coming when rather than put more money into your old system you'll want to consider getting a better system overall.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 6, 2012 10:01 AM   in reply to adambrandrick111
    adambrandrick111 wrote:
    I just don't think they are going to have stock of the 6670 for a while because of the offer and want to get this sorted.
    See if you can find an ATI 5670 then, and try to get one with 1GB of graphics RAM.  I tend to favor performance over price, so you'll have to make your own judgment.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 6, 2012 5:13 PM   in reply to adambrandrick111
    A DDR3-equipped card will be slower than a DDR5-equipped one, but in your case it might not be noticeable as other factors in your system may be the main bottlenecks.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 6, 2012 6:05 PM   in reply to adambrandrick111
    You're welcome.  I know that video card will give you a better computing experience than your onboard Intel GPU.  I just hope it fixes the problem you're seeing - it sure seems as though we've eliminated everything else.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 15, 2012 11:48 AM   in reply to adambrandrick111
    I'm sorry to hear that.  I thought you had sufficiently isolated the problem to your onboard video adapter before.  In any case, the ATI will give you a greatly enhanced computing experience, though it occurs to me that you need make sure all the drivers that were active for the old card have been disabled/removed and the latest ATI drivers installed.
    Can you take a screen grab AND a photo and post them here, so we can see what you're actually seeing?  The gradient screen grabs you put up before all look clean and smooth.
    -Noel
    May 15, 2012 12:09 PM   in reply to emil emil
    I went back and skimmed the whole thread, and at this point I would look very hard at the monitor itself. I agree with what was said above:
    As long as the monitor profile is ruled out, I think it's safe to say that this is not a color management problem. Photoshop color settings should have no bearing on this. And with the video card also ruled out, that basically leaves the monitor. Which one is it BTW?
    I would also like to point out that, like Noel, I see no problem with the examples you posted above (nor with Noel's example).
    PS - the 6670 is a fine GPU. I just got one myself
  • Noel Carboni
    Dec 23, 2006
    May 15, 2012 1:18 PM   in reply to adambrandrick111
    Well, you had done a good job before describing it.
    And you see this when your image is displayed with any application?  Have you tried any tools that avoid any form of color-management - e.g., something like the freeware IrfanView image viewer?
    That sure looks like an egregious color-management problem, but I can see how it could be a monitor problem as well.  But it's hard to imagine, assuming your answer to the above question is yes (it's like that from any app) that it's some kind of system software problem.
    -Noel
1 2 Previous Next
Actions
