Rendering from A E to play in Powerpoint 2007 and am not seeing a transparent background
May 5, 2012 2:24 PM
Tags: #video #render #quicktime #.avi #.mov #after_effects_cs5
Rendering from After Effects to play in Powerpoint 2007 and am not seeing a transparent background in the video. I've tried the combos below and included a snapshot of the render queue:
Which (if any) of the combinations should have produced video with a transparent background? Are there additional values for rendering that I need to change; if so, what are they and what should they be changed to?
(Additional info:
- This project was imported from Illustrator (Document profile = Video and Film)
- Applications:  After Effects, Illustrator (both CS5)
System spec
Video information: NVIDIA, GeForce GTX 480, driver ver 8.17.12.9573
Prod Name: After Effects CS5
Prod Ver: 10.0.2.4
OS: Windows 7, Ver: 64-bit
DirX: 11
Processor: Intel(R) Core(TM) i7 CPU
Memory: 6.00 GB)
Combinations
Render ValuesRender Values
Format - AVIVideo Codec - None
Channels - RGB+AlphaDepth - Millions of Colors+
Color - StraightComp background is black
Transparency grid is on.
Color - PremultipliedComp background is black
Format - Quick TimeVideo Codec - None
Thanks for your assistance
    May 5, 2012 11:59 PM   in reply to lexus124
    PowerPoint doesn't handle transparent video and that's the long and short of it. The only transparency format it supports are PNG images. Everything else will have to be done by baking the background into the video.
    Mylenium
    May 6, 2012 8:45 AM   in reply to lexus124
    No version of PP I know has ever supported transparency in videos. All it does is borrow system components from Quicktime and Flash to dispaly such files, but it doesn't see the transparency to render it to its desktop composition. That's the long and short of it.
    Mylenium
