judid23
Why is PS CS5.1 converting my image??
May 6, 2012 3:47 PM
I am trying to create a card, using a standard layout size of 4.25 x 8.25. I have the resolution set to 300 PPI.
While adding layers, I am also adding in some images to the card for a newborn. The image res is 300 DPI, but once I open the image in PS, then pull it down into the new project, it auto commits to a 72 DPI. I can't for the life of me figure out why it is doing this.
I have tried going into the image>image size and changing it to 300 DPI, but even after I change it, when I go to the file information page, it tells me that the image is still set to 72 DPI.
GRRR!!!! Anyone know why it is doing this?
    May 6, 2012 3:52 PM   in reply to judid23
    What file format are you using?  Some formats don't store resolution values, so they'll come in at the default 72 dpi.  But the pixel count will remain the same.
    May 6, 2012 8:22 PM   in reply to judid23
    Photoshop stores resolution data in JPEG, and EXIF can store resolution data -- but some other applications don't store resolution information.
    It sounds like you might be using another application. If so, which other application are you using?
    And is Photoshop keeping the correct number of pixels and just losing the resolution?
