gloscig
Problem setting the lineThrough for a field
May 6, 2012 5:02 PM
I'm trying to use the FormCalc Initialize event to set the strikeThrough format for one field if another field has any content.  I tried a line from an answer by Stefan to a similar question by Angie Okamoto.  This is is my code:
if (H11-Borrow-Deg.isNull | H11-Borrow-Deg == "") then
          H11-LLAT-Deg.font.lineThrough = "1";
endif
I keep getting this error: "syntax error near token "=" on line 2 column 32"
This is the code from the answer to Angies' question:
if ($ == "1") then // checked
TextField1.font.lineThrough = "1";
TextField1.font.fill.color.value = "255,0,0";
else
I've checked the field names and they are correct.  What am I doing wrong?
  • George Johnson
    Aug 11, 2002
    May 6, 2012 5:17 PM   in reply to gloscig
    You should post this in the LiveCycle Designer forum. This one is for forms created in Acrobat (acroforms).
