i have the echo no results being displayed but when its run it currently displays at the top of the page
if(count($results) > 0){
echo implode($results);
else {
echo "No results were found.";
how do i show the No results were found. in the contents
thanks in advance
no im not but was unsure where this went
this is the header content
<?php
if (!function_exists("GetSQLValueString")) {
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
if (PHP_VERSION < 6) {
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
switch ($theType) {
case "text":
$theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
break;
case "long":
case "int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
break;
case "double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
break;
case "date":
break;
case "defined":
$theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
break;
return $theValue;
$currentPage = $_SERVER["PHP_SELF"];
$maxRows_Recordset1 = 5;
$pageNum_Recordset1 = 0;
if (isset($_GET['pageNum_Recordset1'])) {
$pageNum_Recordset1 = $_GET['pageNum_Recordset1'];
$startRow_Recordset1 = $pageNum_Recordset1 * $maxRows_Recordset1;
$var_SalaryReq_Recordset1 = "xxxxx";
if (isset($_GET['SalaryReq'])) {
$var_SalaryReq_Recordset1 = $_GET['SalaryReq'];
$var_skills_offered_Recordset1 = "xxxxx";
if (isset($_GET['skills_offered'])) {
$var_skills_offered_Recordset1 = $_GET['skills_offered'];
$var_location_Recordset1 = "xxxxx";
if (isset($_GET['location'])) {
$var_location_Recordset1 = $_GET['location'];
$var_PositionReq_Recordset1 = "xxxxx";
if (isset($_GET['PositionReq'])) {
$var_PositionReq_Recordset1 = $_GET['PositionReq'];
mysql_select_db($database_hostprop, $hostprop);
$query_Recordset1 = sprintf("SELECT ID, userid, FirstName, Surname, SalaryReq, PositionReq, location, otherComments, skills_offered FROM think_signup WHERE SalaryReq LIKE %s OR PositionReq LIKE %s OR location LIKE %s OR skills_offered LIKE %s", GetSQLValueString("%" . $var_SalaryReq_Recordset1 . "%", "text"),GetSQLValueString("%" . $var_PositionReq_Recordset1 . "%", "text"),GetSQLValueString("%" . $var_location_Recordset1 . "%", "text"),GetSQLValueString("%" . $var_skills_offered_Recordset1 . "%", "text"));
$query_limit_Recordset1 = sprintf("%s LIMIT %d, %d", $query_Recordset1, $startRow_Recordset1, $maxRows_Recordset1);
$Recordset1 = mysql_query($query_limit_Recordset1, $hostprop) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
if (isset($_GET['totalRows_Recordset1'])) {
$totalRows_Recordset1 = $_GET['totalRows_Recordset1'];
} else {
$all_Recordset1 = mysql_query($query_Recordset1);
$totalRows_Recordset1 = mysql_num_rows($all_Recordset1);
$totalPages_Recordset1 = ceil($totalRows_Recordset1/$maxRows_Recordset1)-1;
$queryString_Recordset1 = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_Recordset1") == false &&
stristr($param, "totalRows_Recordset1") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_Recordset1 = "&" . htmlentities(implode("&", $newParams));
$queryString_Recordset1 = sprintf("&totalRows_Recordset1=%d%s", $totalRows_Recordset1, $queryString_Recordset1);
and this site in the body
<?php
$noresults = "No results were found!";
else {
echo "<p>$noresults</p>";
<?php
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
}if (!function_exists("GetSQLValueString")) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
<?php
// *** Validate request to login to this site.
if (!isset($_SESSION)) {
session_start();
$loginFormAction = $_SERVER['PHP_SELF'];
if (isset($_GET['accesscheck'])) {
$_SESSION['PrevUrl'] = $_GET['accesscheck'];
if (isset($_POST['userid'])) {
$loginUsername=$_POST['userid'];
$password=$_POST['password'];
$MM_fldUserAuthorization = "";
$MM_redirectLoginSuccess = "signup/signup-complete.php";
$MM_redirectLoginFailed = "failed.php";
$MM_redirecttoReferrer = false;
$LoginRS__query=sprintf("SELECT userid, password FROM think_signup WHERE userid=%s AND password=%s",
GetSQLValueString($loginUsername, "text"), GetSQLValueString($password, "text"));
$LoginRS = mysql_query($LoginRS__query, $hostprop) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
if ($loginFoundUser) {
$loginStrGroup = "";
if (PHP_VERSION >= 5.1) {session_regenerate_id(true);} else {session_regenerate_id();}
//declare two session variables and assign them
$_SESSION['MM_Username'] = $loginUsername;
$_SESSION['MM_UserGroup'] = $loginStrGroup;
if (isset($_SESSION['PrevUrl']) && false) {
$MM_redirectLoginSuccess = $_SESSION['PrevUrl'];
header("Location: " . $MM_redirectLoginSuccess );
else {
header("Location: ". $MM_redirectLoginFailed );
<?php
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
} else {
BODY HERE
<div id="CandidateSearchResCont">
<?php
else {
<?php do { ?>
<table width="655" border="0" cellspacing="5" cellpadding="0">
<tr>
<td colspan="2" class="Titlegreen"><table width="100%" border="0" cellspacing="0" cellpadding="0">
<tr>
<td align="left"><a href="candidate-information.php?ID=<?php echo $row_Recordset1['ID']; ?>" class="joblinks"><?php echo $row_Recordset1['PositionReq']; ?></a></td>
<td> </td>
<td align="right"><?php echo $row_Recordset1['skills_offered']; ?></td>
</tr>
</table></td>
</tr>
<tr>
<td colspan="2" class="textblack"><?php echo $row_Recordset1['otherComments']; ?></td>
</tr>
<tr>
<td width="250"><a href="candidate-information.php?ID=<?php echo $row_Recordset1['ID']; ?>" class="smallTXTlinksBlack">more info</a></td>
<td width="405"><div align="right"><span class="pos_salary"></span><span class="pos_location"> <?php echo $row_Recordset1['SalaryReq']; ?>/<?php echo $row_Recordset1['location']; ?></span></div></td>
</tr>
</table>
<?php } while ($row_Recordset1 = mysql_fetch_assoc($Recordset1)); ?>
<p>
<table border="0">
<tr>
<td><?php if ($pageNum_Recordset1 > 0) { // Show if not first page ?>
<a href="<?php printf("%s?pageNum_Recordset1=%d%s", $currentPage, 0, $queryString_Recordset1); ?>" class="smallTXTlinksBlack">First</a>
<?php } // Show if not first page ?></td>
<a href="<?php printf("%s?pageNum_Recordset1=%d%s", $currentPage, max(0, $pageNum_Recordset1 - 1), $queryString_Recordset1); ?>" class="smallTXTlinksBlack">Previous</a>
<td><?php if ($pageNum_Recordset1 < $totalPages_Recordset1) { // Show if not last page ?>
<a href="<?php printf("%s?pageNum_Recordset1=%d%s", $currentPage, min($totalPages_Recordset1, $pageNum_Recordset1 + 1), $queryString_Recordset1); ?>" class="smallTXTlinksBlack">Next</a>
<?php } // Show if not last page ?></td>
<a href="<?php printf("%s?pageNum_Recordset1=%d%s", $currentPage, $totalPages_Recordset1, $queryString_Recordset1); ?>" class="smallTXTlinksBlack">Last</a>
</tr>
</table>
</p>
</div>
I see you haven't defined the variable $results anywhere else in your code. The following PHP function tells the system to count your variable results and if the count is more than 0 in our case, it implodes the results into your table. If the count is not more than 0, then it echos the variable noresults which says 'No results were found'.
<?php
else {
In your case, since you haven't defined the results variable, the PHP script just echos the noresults variable as it doesn't find the results variable anywhere in your code.
i have looked at many variations and they all seem simple but i dont know where to put the code
i obviously need to add the varialble to the sql in the top of the page and the echo in the body
<?php
else {
but what goes where i am unsure of...i have tried variations but non work
any help would be very gratful
thanks
i have just tried this in the php at the head of the document
else {
} else {
and this in the body
<?php $noresults = "No results were found!";?>
but this didnt work
Sorry for the M.I.A. Personal emergency.
results should be a variable before you can use that variable to manipulate data strings.
For example,
<?php
$a[0] = 1;
$a[1] = 3;
$a[2] = 5;
$result = count($a);
// $result == 3
In this $result is defined as a total count of all $a values. This is static PHP. However, in your case, you should define $result to be the value of the actual results of your search query. For example, if you want to validate if your total rows returned from your sql query to be the markup for your PHP function, your code will be as follows:
$result = $totalRows_Recordset1
In this, we define the totalRows in Recordset1 as the total number of all rows in Recordset1. We then use that value as the $result. If you run a count function here, you could say if count is >, return a message saying there are rows present in the table. Else, echo that there are no rows.
Trust this helps.
i thiank you so much for you r help, i understand the concept of
<?php
$a[0] = 1;
$a[1] = 3;
$a[2] = 5;
// $result == 3
and
but i have added this code to my code and it doesnt work, I think i am placing it in the wrong area of the code
i tried adding an else statement..thinking it will read this then move onto the next this but i am getting errors in the code
if
$result = $totalRows_Recordset1;
else
} else {
in the bosy i have
<?php
else {
so i removed the else and just added what you sent
} else {
and even if there are results it is still showing there arent any results?
thanks again for you time
You have the answer to this in your question itself!
Look at how you've configured newParams
You're first querying your DB and you've defined $newparams as an array. Then, you're running a validation on it to find out its count.
Your $results variable should be configured in a very similar manner.
got it sorted thanks you
in the header
$results = mysql_num_rows($Recordset1);
$noresults = 'No results found';
} else {
in the body
<?php
if($results == 0) {
thanks so much for your help
