I'm afraid this isn't working for me either. Build 460. I'm working with the AIR SDK in Flex 4 beta 1. Tab causes a new-line to appear (not a tab) in the TextFlow and then the focusManager kicks in, tabbing to the next Flex control.
The default behavior when there are no tab stops before the end of the line is to create a new line exactly as you describe. Please verify that you've specified tab stops.
This is even simpler than the above.
textFlow.tabStops="tabStops="s100 s200"
will create tabs at 100 and 200 pixels.
Richard
Thanks once again, I was confusing myself with the TabStopsFormat.defaultFormat, thinking that would supply some, it works perfectly when I use the formatted string you provide.
Hi
Is there a way to set a value to tabstop such that every new tab press adds a fixed value of space bet ween two characters
Ashar
