Code Collapse not working
Nov 13, 2009 12:34 AM
My code collapses keep on disapearing.
thanks
    Apr 16, 2012 11:41 AM   in reply to cheggers
    I also have this problem.
    I have 20+ sites that I manage in Dreamweaver CS4 (Version 10 build 4117). Most sites remember code collapse fragments on all files, but I have one site that only partially works. There are two files in particular that show code collapse errors. I can collapse either using the Code Collapse Full Tag button, or I can collapse a selection while I am working on the file. But if I close and reopen, the code collapse fragments are forgotten - this happens even if I save the doc. How do I troublehoot / fix code collapse errors?
    Thanks for your help!
    Jason
    Apr 28, 2012 11:23 AM   in reply to jadan7
    You know you're asking this on the ColdFusion Builder forum, not the DW forum, right?
    Adam
    Apr 28, 2012 11:24 AM   in reply to cheggers
    What do you mean by disappearing?  Previously collapsed code re-expands itself?  The option to collapse code actually disappears from the editor window?  Your question is bit vague...
    Adam
    May 7, 2012 8:12 AM   in reply to Adam Cameron.
    Adam - sorry to post here, I meant to post in DW. To clarify - I select a segment of code, say from line 100 to 200 and collapse the selection. On most projects, when I close DW and come back later, the previously collapsed 100 lines are still hidden. I can click the expand handle and then the code will appear, and I can move on. On a couple cfm files, I will collapse, the same lines 100 - 200, and when I close DW and come back later, the 100 lines are un-collapsed. It looks like there is possibly some sort of corruption in the file that manages the collapsed code.
