My webinar works fine in dreamweaver when I preview in browser but when I go live there is no audio.
The webinar a swf file, all related files are within the same folder, and the entire folder is on the server.
Can you change it to something other than SWF and try a non-Flash method?
Additionally, (and this is an occasional issue with certain servers) have you told your server that the audio portion of the Flash file is playable? With .ogg video and audio, with many Linux-Apache systems, you have to enable that kind of MIME type in the .htaccess file.
I don't know how to convert to another video format. I was given the folder with flash files from the webinar hosting company.
I don't see an audio file.
This is what I have from the webinar host (contents of the webinar file on the server and on my local computer):
numbers.flv
index.html
replay.swf
webinar.swf
When I open index in a browser it works fine. When I open index within Dreamweaver and preview it works fine. Arg...
To be honest, I have zero experience with Webinar. But I work with media all the time, and I'm wondering if you have actually loaded all the necessary files to the correct folder on your server.
I can see these by direct URL:
http://lakestatesfiresci.net/webinars/Recordings/20120119REDPINE/index.html
http://lakestatesfiresci.net/webinars/Recordings/20120119REDPINE/replay.swf
But I can't find any of these:
numbers.flv
webinar.swf
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
Here are the full names for the other files within the folder (I only posted simplifed names above because I just wanted to show the file extensions):
a9e4214527.flv
lsfscwebinar20120119redpinerx.swf
I know that these three files (along with the .html and .swf above) are all that are needed to run the video and sound. I have copied the folder with the 5 files onto multiple machines with different browsers and when I open the .html in a browser the video and sound work fine but as soon as I take the same folder to the server there is no sound.
Make sure you upload the files to the server with the exact same file structure that was present in your desktop version. The sound would have had to be linked in the .swf file so it's not that, but the actionscript used to play the sound will use a relative path. If you change any of the folder names, locations etc, it could mess up the file.
Is the audio in the .flv container? Looks like the .flv is only audio and the graphic elements are completely in the .swf, correct?
While all the other files do download,
http://lakestatesfiresci.net/webinars/Recordings/20120119REDPINE/a9e42 14527.flv
returns file not found.
While it could be a MIME issue, I'd have to question any Web host in this day and age that hasn't yet set the correct MIME type for .flv files.
But however you slice it, the .flv file is not loading in the browser.
Until you/we can do a direct download at the URL listed above, the audio will not work.
Best wishes,
Adninjastrator
Thank you everyone for your help. The file structure is the exact same on my local computer and the server. My co-worker worked on this as well from his home computer and had the same issue when posting on the server. And it happens with all of our webinars - 6 different folders, all different videos, all without sound when posted on the server. I am going to talk to the web host on Monday and mention the MIME issue. I'll let you know if that is the problem. THANK YOU!
There are a handful errors that occur when the .swf communicates with the browser and other internal files. Please see screenshot:
Sudarshan-
Thank you for your response.
Today I disconnected from the internet and opened index.html (run off of my local computer -not the server) in Safari. Everything looked good - the movie played with audio. I believe this means that I have all of the files necessary and that the video does not need to link to the webinar provider, or to any other files. Correct?
I do not know why the .flv file comes up as not found. I have double checked the file name and file path.
Testing the index.html file on your local machine simply means that all the files needed to play your project are on your local machine. That does not give any indication as to what's on the server.
still returns file not found.
Most likely the audio is in that .flv file and without that file you will have no audio. It's not a cross domain issue it's a missing file issue.
You will have to look on the server and make sure that the correct file is in the correct folder and that it's correctly named.
Best wishes,
Adninjastrator
Sudarshan-
I just emptied the cache, disconnected from internet, then tested index.html and it still works fine from my local computer- video with audio.
Adninjastrator-
This morning I tried to reload all of the webinar folders (I've just given you the contents for one webinar folder, but we have 5 others). I deleted the folder "Recordings" on the server. Then in Dreamweaver, I synchronized the entire site with option "get and put newer files." The Dreamweaver search came up with 38 files to "put" from my local machine to the server - all files within the "Recordings" folder on my local computer.
After synch:
Still no audio on the server versions.
http://lakestatesfiresci.net/webinars/Recordings/20120119REDPINE/index .html
Has video but no audio
Still returns an error - page not found
This happens with all 6 webinars on the server. The .html and .swf files work, the .flv files do not. More examples:
http://lakestatesfiresci.net/webinars/Recordings/20120216JACKPINE/inde x.html
http://lakestatesfiresci.net/webinars/Recordings/20120216JACKPINE/acb6 315392.flv
http://lakestatesfiresci.net/webinars/Recordings/20120224WEATHER/index .html
http://lakestatesfiresci.net/webinars/Recordings/20120224WEATHER/a4cb7 32582.flv
Well there are only a few possibilities if you say that you've transferred them....
The .flv files didn't transfer correctly or the Web host doesn't have the correct MIME type set for .flv.
Can you see and compare file size of the files on local and files on server? They should be the same size. If files on server are smaller, then they didn't upload correctly.
You might also want to try using a real FTP program rather than DreamWeaver to upload files to the server. For PCs, use Filezilla:
For Mac:
For MIME issues, contact your Web host.
But the browser will not be able to download the .flv file until you can also do a direct download.... as in posting the like above.
As long as those links return file not found... you won't have audio.
