Johnrh76
still no audio on render!:)
Apr 25, 2012 12:33 PM
I posted before, and still no luck. My computer has good specs, and it was able to render properly once before. I did something to fix it after having this problem, then a month later it happened again. A buzzing noise instead of audio. I tried cleaning the cache, which sounded promising, since this was one thing my friend did for me before it was fixed. But wondering if there is a more thorough way to clean cache than just pressing the "clean" button?
It does have a lot of different types of files including internet clips, but they were able to render before.
Any ideas would be much appreiciated, its a feature film for a good cause, and I've put lots of work into it.
    Apr 25, 2012 1:05 PM   in reply to Johnrh76
    Since you posted before, you should already know that you provide almost none of the needed information for someone to be able to help
    You say you did "something" to fix the problem before... what did you do?
    Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
    What is a CODEC... a Primer http://forums.adobe.com/thread/546811
    What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
    Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing
    For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
    For Mac http://mediainspector.massanti.com/
    http://blogs.adobe.com/premiereprotraining/2011/02/red-yellow-and-gree n-render-bars.html
    If you have a red line over the timeline after importing a video and before adding any effects... your project is wrong for your video... read above about codecs
    Once you know exactly what it is you are editing, report back with that information... and your project setting, and if there is a red line above the video in the timeline, which indicates a mismatch between video and project
    H.264 will NOT work inside an AVI wrapper http://forums.adobe.com/thread/854115
    More information needed for someone to help... click these links and provided the requested information
    -http://forums.adobe.com/message/4200840
    -http://forums.adobe.com/thread/416679
    For CS5 and later, the easy way to insure that your video and your project match
    See 2nd post for picture of NEW ITEM process http://forums.adobe.com/thread/872666
    May 7, 2012 7:45 AM   in reply to Johnrh76
    For the CODEC's, that appear as broken, or corrupted, see this ARTICLE.
    With Export, there are two things that one must consider, when they want a muxed AV file (both Audio & Video Streams in one file), and those are to check both Export Video and Export Audio, and then setting the Multiplexing in the Multipler Tab. It should be set to anything BUT "None," and that will often be "DVD." This ARTICLE goes into more detail.
    Once you have verified that you have done both of those, if there is still no Audio, we can move on.
    Good luck,
    Hunt
    May 7, 2012 8:37 AM   in reply to Johnrh76
    You have all kind or render problems maybe its time to trash your media cash and boot Premiere by holding shift+alt until welcome screen.
    If that does not work a complete reinstall is in order.
    Dont forget to deactivate and run Cleaner Tool.
Incoming Links
