match sublayer by name
May 7, 2012 1:26 PM
I first want to match a top level layer by name then find all group items, but only group items that are under the the "my layer" name and leave the rest of the groups aline. I need to first iterate through the top layers, then through the groupItems, however I cannot seem to access group items as children of layers. here is how I thought it would work.
function findGroups(layerName) {
    for (var i = 0; i < numberOfLayers; i++) {
        var currentLayer = app.activeDocument.layers[i].name;
        if (currentLayer == layerName) {
            var numberOfSublayers = app.activeDocument.layers[i].groupItems.length;
            for (var i = 0; i < numberOfSublayers; i++) {
                // do something
findGroups("my layer");
    May 7, 2012 2:04 PM   in reply to hilukasz
      var numberOfLayers = app.activeDocument.layers.length; // numberOfLayers was not defined
                var numberOfSublayers = app.activeDocument.layers[i].layers.length; // Number of sublayers
                for (var x = 0; x < numberOfSublayers; x++) { // Dont use the i variable twice in the same function. It could work but not best practice.
                    alert(app.activeDocument.layers[i].layers[x]) // Alert the sublayers
    findGroups("My Layer"); // Case Sensitive
    May 7, 2012 2:13 PM   in reply to hilukasz
    don't use i all the time in your for loops, change the second for i's to something else
    for (var j = 0; j < numberOfSublayers; j++) {
    May 7, 2012 2:32 PM   in reply to Mr Clint Eastwood
    Oh where have they put the advanced editor? No code thing… Oh well never mind… This should suffice… getByName() should go in atry catch but you get the idea…
    #target illustrator
    var doc = app.activeDocument;
    var grps = doc.layers.getByName( 'my layer' ).groupItems;
    for ( var i = 0; i < grps.length; i++ ) {
              doc.selection = null;
              grps[i].selected = true;
              app.redraw();
              alert( 'group '+ ( i+1 ) );
    See pic for difference between types…
    May 7, 2012 2:36 PM   in reply to Muppet Mark
    Am I having a bit of a thick moment or do I really have to post then go back and edit to get the advanced features…?
    May 7, 2012 2:52 PM   in reply to Muppet Mark
    hahaha, yes, that's part of the new forum "improvements"
    May 7, 2012 2:57 PM   in reply to CarlosCanto
    I see Jive is going the route of CS… take something useful away then call it an improvement when you put it back… Keep that in mind for your scripts…
    May 8, 2012 5:44 AM   in reply to hilukasz
    That is NOT what I get… Collections have scope to their parent container… When my snippet was run against the pictured doc it selected only the 4 groups in my Layer all other top layers had groups in them…
    May 8, 2012 7:53 AM   in reply to hilukasz
    app.redraw(); is just a script method that should cause the GUI window to update by default this does NOT happen for performace… So using it slows things down… I have had some occasions where it has not worked but a dialog will force that… It shouldn't fix anything but I wanted the highlighted selecion to be visible…
