Full Moon Gal
Blending Layers in CS5
May 7, 2012 3:02 PM
I recently downloaded the trial version of Photoshop Cs5. I haven't had many problems and I like it a lot except for ONE thing! I cannot figure out how to blend layers! When I upload my first layer (my image) it shows in the layers palette.  But when I upload my second layer (texture) it not only jumps on top of my first layer in the layers palette, but it ALSO jumps on top of my first layer (the image) in the work area.  I have watched a lot of the Photoshop tutorials and I've noticed that when they upload their second layer it shows SEPARATELY from the first image in the work area.  They then click on the second layer and drag it over onto the first layer and then they are ready to start working on blending. For the fact that my second layer jumps on top of my first layer in the work area like it does, I am not able to follow along with the tutorials!  I have also tried and tried to figure out how to manage to blend by trying lots of techniques and options in the program but nothing will work.  I use textures and depend on blending A LOT with my editing so this has been very discouraging!  I have used other editing programs and usually with them, after you duplicate your first layer and then upload another you are able to blend with no problem.  So I do not understand this at all!  You can even blend with no problem by duplicating your first layer in Photoshop Elements 10.
If someone could help me with this, it would be MUCH appreciated!  Thank you!
  • Trevor.Dennis
    May 24, 2010
    May 7, 2012 3:47 PM   in reply to Full Moon Gal
    Hi and welcome to the forum
    How are you brining the Texture layer in?  It usually sits on top of the underlying layers with the Place cross on it.   If it is loading as a seperate file then
    Select all Ctr/Cmd a
    Copy Ctrl/Cmd c
    Go to you other image and paste it at the top of the stack Ctrl/Cmd v
    Then you can scroll through the Blend modes and adjust opacity to suite.
    BTW  If I have misunderstood your question, then I am sorry, but cramming it into one paragraph like that makes it hard to follow, and is probably the reason why it took so long to get a reply.
    May 7, 2012 11:07 PM   in reply to Full Moon Gal
    I think you're confusing layers and tabbed images.
    Opening a second image does not place it as a layer in the first document, but if you have tabbed images turned on it will open over the top of the previous image (not the same thing as layers).
    If you want to open each image in a separate window, turn off tabbed documents in preferences.
  • Trevor.Dennis
    May 24, 2010
    May 7, 2012 11:24 PM   in reply to Full Moon Gal
    You can also drag your texture image in from a file folder and it will be Placed over your currently live document in Photoshop.  Just press the Enter key to commit it.  Then you can experiment with Blend mode and Opacity.
    Ctrl/Cmd is a catch-all for Windows (Ctrl) and Mac (Cmd)  We don't always know what system a person is using.
  • Noel Carboni
    Dec 23, 2006
    May 8, 2012 3:58 AM   in reply to Full Moon Gal
    One other tip:
    When you drag images to Photoshop, if you want to open them as separate documents drag them specifically to the EDGE of Photoshop, not into the work area.
    If you drag an image to the work area, it will be placed atop the image already there.
    -Noel
