Replies 1 2 Previous Next
    May 1, 2012 5:42 PM   in reply to trksterq
    After loading the Nikon View software  I was able to view the files via Nikon view and also using Adobe Bridge and process with ACR. Thanks to all - maybe the moral is - Read the manual and don't assume that everything is the same as previously.
    May 1, 2012 10:46 PM   in reply to Jim Omaha
    Jim Omaha wrote:
    I only use Nikon Transfer to renumbering the file to an id with my preferred format (yyyymmdd-nnnn). LR  will do that but since I have LR3
    Not sure if you already know this, but since you said you are going through Adobe Bridge, Bridge CS5 has a powerful Tools > Batch Rename command (better than Lightroom's rename in some ways), so that you don't have to rename with Lightroom or Nikon Transfer.
    May 2, 2012 1:02 AM   in reply to Conrad Chavez
    Very true. I've not bothered to even install any Nikon software on my computer - no need as the various Adobe applications do the same job, and often more efficently too. You could also use the Adobe Photodownloaded (comes with Bridge/PS) to transfer files from the card to your hard drive (or LR, as ssprengel notes); no need to even use Windows Explorer or Mac Finder.
    M
    May 7, 2012 2:32 PM   in reply to trksterq
    So D800 RAW finally worked when the ACR 6.7 update came along, then I upgraded to CS6, got ACR 7 and again it doesn't work. Slightly disappointed here. :-(
    May 7, 2012 2:39 PM   in reply to iJoost7
    ACR 7.0 does not have support for the D800 or D800e, but ACR 7.1 does. If you would like, you can download ACR 7.1RC from the adobe labs. http://labs.adobe.com/technologies/cameraraw7-1/ Thanks!
    May 7, 2012 2:44 PM   in reply to adriana ohlmeyer
    Ah well... I guess I'll have to do another RC then. ;-)
    Thank you for the pointer.
    May 7, 2012 2:48 PM   in reply to iJoost7
    No problem, let me know if it works for you!
    May 7, 2012 2:56 PM   in reply to adriana ohlmeyer
    Well, it's midnight here... so I won't be doing much "testing" right now. But sofar it did open a NEF correctly for me. :-)
    May 7, 2012 6:37 PM   in reply to iJoost7
    Great! Thank you for letting us know. :-)
    May 8, 2012 11:41 AM   in reply to adriana ohlmeyer
    I installed PSCS6 which on Snow Lepord which worked, but when I installed ACR 7.1 in Snow Lepord PSCS6 would no longer open. Error was program corrupted or incomplete.
    If I upgrade to Lion than my network to PCs fail due to Apples change in Samba.
    May 12, 2012 12:28 PM   in reply to adriana ohlmeyer
    I have downloaded and installed ACR 7.1 but it is only partially functional with regards to my D800 NEFs.  For example, in the Filmstrip workspace, it will generate thumbnails of the NEFs and, when double-clicked, ACR is launched and I can post-process the NEF.  However, when I simply select a particular NEF, a preview of the image does not appear only a generic NEF icon.  I tried to insert a screen capture showing this but was informed that this type of content wasn't allowed.
    May 12, 2012 1:08 PM   in reply to Chazmi
    Download and install S-NEFCDC-011400WF-ALLIN-ALL___.exe
    from WWW.NikonUSA.com
    May 12, 2012 1:22 PM   in reply to Chazmi
    ACR only supports interpretation of NEFs within an Adobe product.  When you are using a file selection dialog to choose files, this is Adobe using an OS-level function, not Bridge or Photoshop, so you will need an update to the OS or provide it an OS-level plug-in to show the previews, with the link in the other reply being a possible choice.
    If you are saying that Previews within an Adobe product are not showing, perhaps the ACR cache needs cleared.
    Jul 15, 2012 12:39 PM   in reply to ssprengel
    I'm stuck here too, I have a new iMac,  the Adobe Photoshop suite Cs5 and a new nikon D800.  I can't open my nef files either, not in PS, Bridge, Lightroom.   I've tried to install ACR 7.1 and I'm told I don't need it by an error.  I installed the earlier version of ACR and that doesn't help.  So now what?  I got lost and missed the solution to the problem.
    Ok, humble pie here.  Apparently I can't read the difference between 6.1 and 6.7.  6.7 did work.  Sigh, oh my tired brain.
  • Noel Carboni
    Dec 23, 2006
    Jul 15, 2012 1:09 PM   in reply to Cosmichrist
    Well, to be fair 1 and 7 are both straightish runes with a little tab coming off the top.
    Glad to hear you're up and running.
    -Noel
1 2 Previous Next
Actions
