I have my photos on an external HDD that seems to be failing. My Lighroom library is found on this failing HDD. I want to move the photos to a new external HDD. What's the best way to transfer the photos to the new HDD and have Photoshop use that as the new library?
I image this has been asked before and I apologize for asking again, but I can't seem to find best answer.
Thanks fo the patience.
If Windows, you can transfer all the files using Windows copy and paste to the new HD, keeping the exact same folder structure and folder names and file names. Then disconnect the old one, plug in the new one and make sure the drive letter of the new one is the same as the old one was using (i.e. if the old HD was E:\, then after unplugging the old one and plugging in the new one, make sure the new one is E:\)
If Mac ... someone else will have to provide help.
muelgrub wrote:
But how about this: What's the easiest way to completely delete my Lightroom libray, and just start over and import the same photos but now like it's the first time. Can that be done?
Starting your catalog over from scratch is a good idea if you don't mind losing all your keywords, all your edits, all your collections, your virtual copies, your slideshows and everything else you have done in LR. It's a good idea if you don't mind doing all the extra work of replacing all the information you lost. So ... what's the easiest way? Just do it!
I believe you that it works, I just couldn't figure it out. When I went to Step 1: File->New Catalog like you suggested, a window opened that asked to put in a file name, not simply point to a different drive. Ultimatley, I got it to work by just deleting the old catalog and adding a new catalog. Now LR does open the photos on the new hard disc. What I wanted to do, hoever, was to put the photos on the new HDD and then re-import them back into LR as if it was a fresh install so that I could add attributes to each photo like copywrite etc. Not a big deal really, I'll do without that and just keep things as they are.
thanks for the help!! ![]()
No need to delete your old catalog, just in order to add some metadata as you would in a fresh import!
You can mass-edit copy rights or any other metadata anytime.
Victoria Bampton describes this very well in her "The missing FAQs LR".
Get her eBook from http://www.lightroomqueen.com/books/adobe-lightroom-4-missing-faq/ (14.95 British Pound well spent).
Cornelia
