Still no live Scopes?
May 7, 2012 6:38 AM
As one of my requested features I was hoping that vector scopes would be (or could be) live while you were playing the video in the main monitor.
Is there STILL no way to see composite video AND vectorscopes updating at the same time in CS6?
Did I miss something here?
    May 7, 2012 3:43 PM   in reply to ExactImage
    Sorry, scopes still do not update as you playback in CS6. Feature requests: http://www.adobe.com/go/wish
    May 7, 2012 3:53 PM   in reply to ExactImage
    I know how you feel, but actually, it does make a difference. As feature requests for a particular feature accumulate, they grow in importance to the Premiere Pro team.
    May 7, 2012 5:03 PM   in reply to Kevin Monahan
    I just added my voice to the crowd.
    May 7, 2012 6:12 PM   in reply to Jim Simon
    Me too!
    May 7, 2012 7:27 PM   in reply to ExactImage
    CS6, Win 7
    Guys.
    I just tested ...and both Vector scopes and YC Waveforms are updating to playback and scrub  in my system with the very latest Nvidia drivers for  my FX3800 Quadro.
    May 7, 2012 7:48 PM   in reply to shooternz
    Interesting, shooternz. Let me go find out the specifics.
    May 7, 2012 8:04 PM   in reply to Kevin Monahan
    Keep in mind that the O.P actually said...
    So I have the composite video showing in my second monitor and the scopes showing in the Program Monitor. ie. it is possible in realtime and simultaneously
    May 7, 2012 8:45 PM   in reply to shooternz
    Very cool, shooternz.
    May 7, 2012 8:53 PM   in reply to Kevin Monahan
    Others have commented similarly about me .
    May 7, 2012 10:51 PM   in reply to shooternz
    I tested myself.  No live update to the reference monitor, no matter what it shows, using a GTX 560 Ti with 296.10 driver.
    May 7, 2012 11:48 PM   in reply to Jim Simon
    Maybe the power of Quadro Cards.
    Be interesting to hear from others.
    @Jim.  Why are you using the reference monitor for this function?
    What happens if you play out to your second monitor and set your Primary Program Monitor to scopes (or any of the scopes)?
    I will try the reference monitor to see what happens in my system / set up.
  • Jon-M-Spear
    Jan 27, 2006
    May 8, 2012 12:03 AM   in reply to shooternz
    Brilliant shooternz:  Quadro FX3800 and 3rd monitor through BM Intensity Pro.  Go to the top of the class.
    By the way, you're really going to want to dust down your BM Intensity Pro now that it's sooooooooooooooo integrated.  Just set the card as the playback viewer in Preferences and use an Adobe codec as per usual.
    Equally as cool!
    May 8, 2012 12:52 AM   in reply to shooternz
    If I set my external device to my 2nd monitor and display composite video on it and set the program monitor on my Sager X7200 laptop to all scopes, everything updates real time (Nvidia GTX580M card - 280.26 drivers).
    Still using PP5.5.2 at the moment.
    If I use the "Color Correction" workspace and try to display the composite video and all scopes on the same monitor the scopes do not update in real time.
    May 8, 2012 12:18 AM   in reply to Jon-M-Spear
    @ jon - sorry if i'm misinterpreting, but i'm coming from vegas pro where i can playback my timeline using any codec on it and monitor via bm intesity pro. are you saying i have to use a 'adobe' codec in order to do that!?
    btw. i have a gtx550ti and live scopes with vegas. i'm presuming i'll still have live scopes?
  • Jon-M-Spear
    Jan 27, 2006
    May 8, 2012 12:55 AM   in reply to leslie wand
    Leslie, up to CS5.5, if you wanted to use the BM Intensity Pro for 3rd monitir preview only, you had to create a sequence using a BM codec.  That was the main gripe.
    In CS6 the BM IP is now used in the background, and you set the card as the viewer - much the way AE handles it.  That means you're free to use a sequence setting of your chosing.  I'm hoping that means that we can now copy the PP CS6 project files over to a laptop that doesn't have a BM IP installed - without needing to load the BM codecs - as I currently have to do.
    I haven't tested it to destruction yet - but it seems to be holding up well.
    May 8, 2012 2:40 AM   in reply to shooternz
    WOW, i have live update too.
    As Craig said. Scopes in the Program Monitor.
    Scopes in other monitors dont work.
    And i only have a GTX 285.
    May 8, 2012 9:21 AM   in reply to shooternz
    How else do you see both composite and scopes at the same time using one physical monitor?
    May 8, 2012 10:42 AM   in reply to Ann Bens
    @Ann I'm using GTX 285  on latest Mac Pro. What NVidia Drivers are you using and what OS version?  We are talking about CS6 I assume. Thanks
    May 8, 2012 11:05 AM   in reply to DMHP
    I am on a PC and yes CS6 and CS5.5.
    May 8, 2012 12:05 PM   in reply to shooternz
    I just got this info from engineering:
    If you want to view both live scopes and composite video, you'll need a second monitor connect to your graphics card or 3rd party I/O device (AJA, Matrox, BMD, BlueFish) to make this work.
    Set you Program Monitor to one of the scopes via the Program Monitor panel menu
    Set your Prefs >Playback to Adobe Monitor 2 (or 3rd party I/O)
    I also see my Program monitor, when set to scopes, playing back scopes live.
    May 8, 2012 12:08 PM   in reply to Jim Simon
    Hi Jim, see my earlier message.
    Set your Prefs >Playback to Adobe Monitor 2 (or 3rd party I/O).
    May 8, 2012 12:12 PM   in reply to Jim Simon
    I thought you used a separate calibrated monitor and a second monitor.  Anyway as posted...you need 2 monitors.  My set up that we have discussed at length previously works even better in CS6 I must add. Its absolutely brilliant!.
    Will see what the reference monitor and scopes issue when I go in this morning.
    I will be reinstalling the BM Card so I can access another monitor and see how to take advantage of it.
    May 8, 2012 12:15 PM   in reply to shooternz
    This is a great thread. I'll make sure the specifics get into documentation.
    Shooternz, I'm glad your setup is working better than ever!
    May 8, 2012 6:35 PM   in reply to Kevin Monahan
    Well sure but...that's not the point.  The point is to make the reference monitor update live, whatever it's showing.
    May 8, 2012 6:38 PM   in reply to shooternz
    I used to, but things changed.  I've gotten pretty good at using a sort of mental LUT for my reference monitor, which is now only hooked up to the Blu-ray, so I can get pretty close without it directly hooked up to PP.
    May 8, 2012 6:41 PM   in reply to Jim Simon
    Just curious then...why not a second monitor?
    May 8, 2012 6:45 PM   in reply to shooternz
    It'll be coming back into the chain (assuming the BM Intensity Pro works as I hope it will.)
    Still, it shouldn't be necessary for this scenario.  We already have that 'second monitor' with the reference monitor.
    May 8, 2012 6:56 PM   in reply to Jim Simon
    I thought you did not want a 3rd party solution to external monitoring!
    CS6 and 2 monitors is a real dream and with the CTRL - Tilde option...its heaven on a stick.  (Transmit)
    The Reference monitor does not even compare practically as a viable monitor for anything but comparing scene to scene and I am somewhat surprised to hear you suggest you are using it for CC and Grade..
    May 8, 2012 6:59 PM   in reply to shooternz
    Ideally, it would happen correctly just using the graphics card, but...with Adobe Transmit it sounds like we get most everything in a Proper Monitoring Solution minus that, so...close enough I guess.
    Or, if it worked correctly, seeing live scopes and live video.
    May 8, 2012 7:47 PM   in reply to Jim Simon
    Ahhhh...but you cant calibrate it.
    And BTW  Jim...Transmit works great using the graphics card. You just need to bring yourself around to trying it.
    And a tip.  The New HD Color Bars are awesome to set up the Monitors with.
    May 9, 2012 10:57 AM   in reply to shooternz
    You don't need to calibrate the reference monitor for showing scopes.
    May 9, 2012 10:58 AM   in reply to shooternz
    Do you still have to extend or clone the desktop?  Or can PP now see the second monitor without Windows knowing about it?
    May 9, 2012 1:20 PM   in reply to Jim Simon
    You also mentioned "live video" in the reference monitor.  I assumed you were using it instead of  a second monitor.
    Jan 5, 2013 2:08 PM   in reply to shooternz
    re: Set your Prefs >Playback to Adobe Monitor 2
    thank you kevin monahan - this works great (with FX4000).  getting live waveform + live video full frame on 2nd monitor, and with SD, also simultaneous component video on a monitor connected to a DV deck.
