Master page graphic frame behavior
May 7, 2012 1:41 PM
Tags: #master_page_graphic_frames
I am new to InDesign. I have created a master page that has 4 graphic frames on it. If I create a page based on the master and I try to place an image in each frame, it only works for the first frame.  Each subsequent place just put the image into the page but not one of the defined frames setup in the master.
Can someone tell me why this happens? And if this is what it is supposed to do, how do I accomplish creating a page based on a master that has 4 frames to accept graphics.
Any help is appreciated.
    May 7, 2012 1:57 PM   in reply to somedaymetalkpretty
    A screen shot of your page would help, along with more details about how you are placing the images. It should be working, so there's probably something about what you are doing that is a problem.
    And tell us your OS and the version of ID, please.
    May 7, 2012 3:19 PM   in reply to somedaymetalkpretty
    If I understood right , You have the page based on the Master page that has 4 graphic frame....
    As if I know , you cannot place the image in the graphic frame which is on the master page unless it is not overridden , So if you have 4 graphic frame on master page say "A"
    You create the page based on "A" master , to use the graphic frame you have "Shift+Ctrl" or "Shift+Cmd" on the graphic frame to override it and then you can place the image in that frame , if you will not do so you even can't select these frames.
    May 7, 2012 3:20 PM   in reply to somedaymetalkpretty
    Check to be sure you didn't lock the frames.
    If that doesn't work, you might want to try trashing your prefs. see Replace Your Preferences
    May 7, 2012 3:45 PM   in reply to Manish-Sharma
    @ Manish,
    It should make no difference whether the frames are overridden or not.
    May 7, 2012 3:51 PM   in reply to Peter Spier
    @ Peter,
    This will not make difference if he is working on master page , but no the page based on master page I believe he has to overirde otherwise how he will select the frame in which he want to place the image.
    Have I misunderstood the OP?
    May 7, 2012 4:00 PM   in reply to Manish-Sharma
    No. Even on the document page you don't need to overrride. If you hover over an open area in the frame you should see the cursor change, and if you click the image will be placed at 100% in the master frame and it will automatically override ont the document page, just like a text frame. Try it.
    May 7, 2012 4:05 PM   in reply to Peter Spier
    Cool....Always learn new think...Thanks a lot Peter.
    May 7, 2012 4:34 PM   in reply to somedaymetalkpretty
    I believe you are on Mac Lion on which the user library folder is hidden ,
    Press "Option" key on the keyboard (keep it pressed) and then click on the "GO" button in the menu bar on top.
    You will see library option , click on that it will open the library folder and then folloe the rest of the path
