Photo won't open when sent to Photoshop CS6 through LR4's 'edit in' feature
May 7, 2012 8:43 PM
Tags: #lightroom #cs6 #edit_in #lightroom_4 #lr4 #lightroom4 #external_editing #cs6_opening_problem #acr7.1
Everything is up to date (ACR 7.1, and Lightroom 4.1). When I choose to edit in CS6, the program will open but my chosen photo does not appear. I can't figure out what is going on! Please help!
    May 10, 2012 11:33 AM   in reply to idc215
    I am having the same problem, very frustrating!  Please help with this issue!
  • Andrew Rodney
    Apr 16, 2009
    May 10, 2012 11:59 AM   in reply to TeresaLynnSchmidt
    In the past, the Edit In functionality could be flaky depending on the order you installed LR and Photoshop. Might want to reinstall Lightroom after Photoshop CS6. May work.
    May 10, 2012 6:00 PM   in reply to idc215
    If you are on Windows... You can find the most likly reason for the problem by looking at my post from 5/10 -
    http://forums.adobe.com/message/4395065
    IT seems that it is as an issue with the 64bit versions of Bridge and Photoshop
    May 10, 2012 7:01 PM   in reply to idc215
    IM not at my computer so I can't try this out but look at this thread
    http://forums.adobe.com/message/4393544
    But in answer to your question no you don't ever use the application the problem is in lightrooms inability to create the psd... A psd is a psd irregardless which verson of photoshop you use 64 or 32 bit.
    IN looking over the solution provided in 4393544 it sounds like it will resolve the issue your having please post if it does resolve the problem... Are you gritting the UAC message??
    May 10, 2012 7:04 PM   in reply to evan.sante
    May 11, 2012 10:48 AM   in reply to idc215
    IF YOUR GOING TO REPLY DO SO AT MY ORIGINAL POST - http://forums.adobe.com/message/4395818#4395818
    I'm on Windows so I can't be of much help... I tried the solution I posted last night (http://helpx.adobe.com/x-productkb/multi/edit-photoshop-command-missin g-photoshop.html) and it didn't work uninstall / reinstalling CS6 also doesn't work!! Finaly I went into the Registry and removed all referances to Adobe\Adobe Photoshop CS5.1 (there are a number of them) and pointed them to Adobe\Adobe Photoshop CS6 but that also doesnt work!!!
    The only solotion sofare is what I posted earlier... adding a pointer in "Edit In" to the 32bit version of Photoshop. Dut as I stated it still dosen't alow me to open in Photoshop as a Smart Object -- I GIVE UP!!!!
    May 30, 2012 1:35 PM   in reply to idc215
    Me too.  Having this problem on my MacBook Pro but, oddly enough, it works fine on my MacBook Air. I've tried every possible combination of uninstalling and reinstalling to no avail.
    To add a little more detail -- it works when if I choose "Edit a Copy" or  "Edit Original". If I choose "Open as Smart Object in Photoshop" the file opens but any attempt to save gives an error:
    Error 2: photoshop is undefined
    Line: 1
    ->  photoshop.notifyLightroomDocSaved ('lightroom-2.0', '39BCF4F2-8E18-44C5-94F5-758BBBF83DBA', 'Macintosh HD:Users:gregdem:Pictures:2011:2011-09-18:_MG_6004-Edit.tif');
    May 30, 2012 1:46 PM   in reply to gregdem
    Have you got the right version of ACR for your version of CS? For CS5 you need ACR 6.7 and for CS6 you need 7.1. Editing as a smart object uses ACR not LRs built in version of ACR. Having CS set as a secondary editor, uses LRs built in ACR and not the external ACR, I think!
    Bob Frost
    May 31, 2012 9:27 AM   in reply to idc215
    Are you sure you are waiting long enough? It will not show up in CS6 instantly. I am on a Vista machine, and it takes a good 30 seconds after CS6 opens before the image appears. The rotating do-dad does not even show up for 15-20 seconds.
