Polygon Jedi
Loaded youtube video appearing above other layers. Help needed on getNextHighestDepth ()
May 8, 2012 12:23 AM
Tags: #depth #youtube_video #getnexthighestdepth
Dear All,
I have loaded a youtube video inside a flash and also couple of other mouseover pulllout animations As of now the youtube video is loading above the other animations. If I replace the youtube video with a couple of images everything works fine. But with the youtube video. i'm not able to see the mouve over effects.
Here's how I loaded the animation:
function checkBounds1(X, Y, W, H)
    bounds1.onEnterFrame = function ()
        var _loc2 = _root._xmouse;
        var _loc3 = _root._ymouse;
        if (_loc2 < X || _loc2 > X + W || _loc3 < Y || _loc3 > Y + H)
            delete bounds1.onEnterFrame;
            checkBoundsCallback1();
        } // end if
} // End of the function
function checkBoundsCallback1()
    promo1_anim.gotoAndPlay("out");
    promo1.enabled = true;
promo1.onRollOver = function ()
    promo1_anim.gotoAndPlay("in");
    this.enabled = false;
    checkBounds1(0, 0, 338, 228);
var bounds1 = createEmptyMovieClip("bounds1", getNextHighestDepth());
And here's how I loaded a youtube video:
// create a MovieClip to load the player into
var ytplayer:MovieClip = _root.createEmptyMovieClip("ytplayer",0);
// create a listener object for the MovieClipLoader to use
var ytPlayerLoaderListener:Object = {
  onLoadInit: function() {
    // When the player clip first loads, we start an interval to
    // check for when the player is ready
    loadInterval = setInterval(checkPlayerLoaded, 250);
var loadInterval:Number;
function checkPlayerLoaded():Void {
    // once the player is ready, we can subscribe to events, or in the case of
    // the chromeless player, we could load videos
    if (ytplayer.isPlayerLoaded()) {
        ytplayer.addEventListener("onStateChange", onPlayerStateChange);
        ytplayer.addEventListener("onError", onPlayerError);
        clearInterval(loadInterval);
ytplayer.setSize(850,493);
ytplayer._x = 95;
ytplayer._y = 0;
function onPlayerStateChange(newState:Number) {
    trace("New player state: "+ newState);
function onPlayerError(errorCode:Number) {
    trace("An error occurred: "+ errorCode);
// create a MovieClipLoader to handle the loading of the player
var ytPlayerLoader:MovieClipLoader = new MovieClipLoader();
ytPlayerLoader.addListener(ytPlayerLoaderListener);
// load the player
ytPlayerLoader.loadClip("http://www.youtube.com/v/2K2554Wxssk&autoplay=1&loop=1", ytplayer);
The animation code has been working for years now. I think all this has got to do with the getNextHighestDepth (). I have tired giving values like 0 and 1 but ended up helpess.
Any help would really great at this point.
Thank-you.
