NicolasDeVuyst
Adobe Acrobat X Pro
Jan 9, 2012 1:56 PM
Tags: #acrobat #x #adobe #pro #cs5.5 #serial
Hello,
I just installed my cs5.5 master collection.
All runing fine so far except Adobe Acrobat X Pro.
When trying to launch it requires a serial, I fill the fields with my cs5.5 serial but it warns me it is incorrect.
I mention the same serial I used when installing the cs5.5 master collection.
Is there another serial for Adobe Acrobat X Pro ?
    Jan 9, 2012 4:06 PM   in reply to NicolasDeVuyst
    Have you opened any of your other Adobe software?  Adobe Acrobat should have become serialized when launching one of your other creative products.
    Jan 10, 2012 10:10 AM   in reply to NicolasDeVuyst
    I would recommend removing Acrobat then and reinstalling.  Once reinstalled try launching Photoshop or one of the other creative apps before your first launch of Acrobat.  In case we need to perform additional steps which operating system are you using?
    Jan 11, 2012 8:55 AM   in reply to NicolasDeVuyst
    I see then our next step will be to remove Creative Suite 5.5?  Do you have any other Adobe software installed?  Depending on the application the following steps might affect those applications as well.  Please post back before proceeding if you do have any other paid Adobe applications currently installed.
    Once Creative Suite 5.5 is removed then navigate to \Library\Application Data\Adobe and delete the following folders.
    Adobe PCD
    caps
    This will remove the stored serial numbers on your computer, which is why we wanted to remove Creative Suite 5.5 first, once done then reinstall Creative Suite 5.5 making sure to launch one of the creative products first as previously discussed.
    Jan 13, 2012 11:02 AM   in reply to NicolasDeVuyst
    NicholasDeVuyst if you are continuing to experience the same difficulty then you maybe facing a permission issue with your account.  I would recommend logging in as a root user and trying the suggested steps again while under the root user account.
    Feb 13, 2012 4:44 AM   in reply to Jeff A Wright
    Hello Jeff,
    I've got the same problem :
    - New Creative Suite 5.5 Master Collection
    - Fully installed
    - The only applications asking for an other SN are Acrobat X Pro and Distiller
    Any suggestions ?
    Feb 13, 2012 5:05 AM   in reply to NicolasDeVuyst
    Solution found : Switching language is the solution ... poor solution
    The issue comes from the language used by the OS.
    Acrobat allows you to use it only if you have set up English as the preferred language in the OS.
    Bad news.
    Would like to have a sort of patch or a kind of nudge from Adobe to resolve the problem.
    Feb 13, 2012 5:40 AM   in reply to NicolasDeVuyst
    Kind of solution (from : http://hints.macworld.com/article.php?story=20110522014935224 )
    It works (but not sure it is stable enough)
    Starting foreign language Acrobat on English OS X
    Acrobat 10 doesn't accept serial numbers for international versions of Acrobat (or the CS suite) if the operating system is running in a different language than the purchased one. This hint discusses a few workarounds.
    Acrobat comes with several language packages and runs by default with the language of the operating system. In this case however it doesn't accept serial numbers which are bound to a specific language. As it seems there are three work arounds (the first two are also mentioned by the Adobe support team):
    The obvious one: Run OSX in the same language as Acrobat was purchased in. At least in my case not an option.
    Use a program such as Language Switcher. http://www.tj-hd.co.uk/en-gb/languageswitcher/
    May 8, 2012 12:56 AM   in reply to nudgeproductions
    u were right, i just switched the language of the operating system (my  mac) to the same as the purchased one, and suddenly it works, no problems. WEIRD. good to know. thanks!!!
