Brezhnev29
Sending email using SMTP in Flex 3
May 8, 2012 2:36 AM
Tags: #flex
How to send Email using SMTP in Flex 3.
    May 8, 2012 2:40 AM   in reply to Brezhnev29
    What backend are you using?
    May 8, 2012 2:49 AM   in reply to Brezhnev29
    Ok
    In this case Im really not sure.
    Do you want to send an email directly or trigger the application to open a blank email for a user to then fill in and send?
    The later can be done as you would in html
    To have flex send an email directly though you need to connect to an email server
    Is this a flex web app or a flex air app?
    If it’s a web app you could add a small amount of PHP of coldFusion code depending on your hosting and write a small script that flex would then call to trigger the email sending
    Let me know and I will try to help if at all possible
    Sorry to not have simpler answer for you
