[UI BUG] Set Copy As Master -> still referred as "Copy"
May 7, 2012 7:30 AM
Tags: #lightroom4 #virtual_copy #set_copy_as_master
I just found a small UI glitch.
I selected the Set Copy As Master command to promote a virtual copy.
http://f.cl.ly/items/1C2S3r342G090p2c472j/Screenshot%20%202012-05-07%20at%2016.05.20.png
As you can see, the page curls is gone, but the file name is still "Copy 2".
http://f.cl.ly/items/0G0V2n381c0y293k0n0l/Screenshot%20%202012-05-07%20at%2016.05.58.png
Can you reproduce this? Is it by design?
    May 7, 2012 8:21 AM   in reply to PaoloAvezzano
    I doubt it's by design, but I can reproduce.
    May 8, 2012 3:09 AM   in reply to PaoloAvezzano
    I'm not sure it's a bug and it's certainly not an UI bug.
    Each image in the catalog, be it a master or a copy, has a database field
    (adobe_images.copyName) that stores the copy name. Note that you can also
    use it for masters. It is associated with a certain image, not with the
    fact that a imge is a copy or a master.
    Imagine a situation where you have a master and a copy converted
    black-and-white with the copy name "BW" or an alternative crop with the
    copy name "Croppped". Now, if you swap the master with copy, should the
    master get a "BW" or "Cropped" copy name? I guess not.
    Thanks, that makes sense.
    May 8, 2012 4:01 AM   in reply to PaoloAvezzano
    The virtual copy has no specific name other than "Copy x".
    No, because you did't set it. That's an automatically generated name, but you're free to change it to whatever you want.
    So the master has the real name and the copies have theoretically the same.
    NOt sure what you mean. I assume you do understand that the CopyName and File Name are two different attributes. A Copy always shares the same filename with the master, but the the copynames may be arbitrary for both. By default, Lr4 displays the filename for the master and the copyname for the VC. You can change that in View Option (Ctrl+J).
    this means that the "Set Copy As Master" is not a lot useful.
    Agree. There's no point in doing that (besides the curled triange display). Internally, masters and copie are treated exactly the same.
