Quick Question: CS6 Installation Best Practice
May 8, 2012 6:46 AM
Hi Guys
I have CS5 and CS5.5 Master Collection running on my PC (Win7 64bit SP1, Intel Core i7 2.67ghz, 24 gig RAM) and I've just taken ownership of the CS6 upgrade. When I loaded MC CS5.5 I had a bunch of errors, which turned out to be related to the update not needing to replace certain existing components of CS 5.
Should I just insert the disk and run or is there anything I should do to prepare this time? Any advice is welcome. I'd like to avoid uninstalling the previous versions but if that's the advice, I'll run with it.
Graham
    May 8, 2012 6:49 AM   in reply to glaustin
    I think you already have asked this question , http://forums.adobe.com/message/4348997
    Thinks would remain the same for CS5.5 and CS6 , If you face any issue do let us know , we will help you?
    May 8, 2012 12:52 PM   in reply to glaustin
    If you need the flash builder and is very important for you then ,
    Go to control panel and Uinstall CS5.5 , when you start the uninstall the screen with all the product name will come up , just check flash builder and uncheck everything , It would remove just flash builder.
    But forget it f you dont need it or doesn't use it.
