maxwelladdicted
Access a code generated MC for hittest
May 8, 2012 9:12 AM
Tags: #cs5 #action_script_3 #gui #snapping
Hi every body
I've been looking around without great success to solve this little problem of mine and it goes like this;
By clicking two button on stage I create two MovieClips called EVE and BLOCK... That's because the buttons display objects with addChild.
function newMcEvent():void
          var eve:MovieClip = new event_graphic();
          eve.x = 50;
          eve.y = 350;
          eveNum++;
          eve.name = "eve " + eveNum;
          addChild(eve);
          eventArray.push(eve);
          for (var i:int = 0; i<eventArray.length; i++)
                    eventArray[i].addEventListener(MouseEvent.MOUSE_UP, touch);
                    eventArray[i].addEventListener(MouseEvent.MOUSE_DOWN, drag);
                    eventArray[i].addEventListener(MouseEvent.MOUSE_UP, noDrag);
                    eventArray[i].addEventListener(MouseEvent.MOUSE_DOWN, snap);
function newMcBlock():void
          var blc:MovieClip = new block();
          blc.x = 50;
          blc.y = 350;
          blcNum++;
          blc.name = "blc " + eveNum;
          addChild(blc);
          blockArray.push(blc);
          for (var i:int = 0; i<blockArray.length; i++)
                    blockArray[i].addEventListener(MouseEvent.MOUSE_UP, touch);
                    blockArray[i].addEventListener(MouseEvent.MOUSE_DOWN, drag);
                    blockArray[i].addEventListener(MouseEvent.MOUSE_UP, noDrag);
BLOCK has the same code as EVE and has also a small invisible area that I want to use for snapping objects (called SNAP, it's a nested movie clip!)...
What I want to do is to add to EVE an EventListener.MOUSE_DOWN that triggers a function called snap... this way I can check if EVE is actually HitTesting the movie clip BLOCK....
I manage to write down this code
function snap(e:MouseEvent):void
          if (e.currentTarget.hitTestObject(Object(root).blc))
                              trace("ok");
It returns Error #2007: Parameter hitTestObject must be non-null. which I take as the fact it can't find BLOCK or some reason, but it's there I swear!
Any idea?
  • kglad
    Jul 21, 2002
    May 8, 2012 10:40 AM   in reply to maxwelladdicted
    you made blc local to newMcBlock() so it's not available outside that function.
    you can either remove the local function reference or use getChildByName() and use blc's name property to reference it.
