I've been searching for a means of importing graphic quality when importing a word doc with graphics to rh. Linking the graphic files in word instead of embedding them seemed to be an effective solution. But only when compiling to web help. Oddly enough, when I compile to a chm (after importing the word doc, and the linked graphics displaying in rh), all the linked graphics disappear - from rh, from the word document, and even from the graphics folder where they were saved. It is the strangest thing. I've tested this extensively in RH8, and somewhat in RH9. Does anyone have any advice regarding this or know if Adobe is planning on solving this major bug? Has anyone found an efficient way of improving graphic quality (especially of screen captures that were resized) other than manually inserting them in the RH project? TIA.
First of all, there is no bug here. Resizing graphics is an issue regardless of whether or not you are working with RoboHelp.
Second, linking is not supported, the images must be embedded in the Word document.
Now let's look at the general problem. First see http://www.grainge.org/pages/various_rh_projects/images/index.htm. It's an old topic but I believe the general information holds good. More recently I found something else that may be relevant. I needed to resize some screenshots rather than some other image. As soon as I applied any resizing, the text became ugly. That led me to suspect that the tool the developers use to create the screens can have an impact when resizing. I haven't had a chance to test that yet by working with screens from different products using differerent tools.
Open one of your Word documents and right click on an image that is giving you grief. Use the Save Image option and save the image as a jpg or whatever. Then open that in a grapics editor. Recently I tried to help someone whose image size was something like 5000 pixels wide. Given the average screen size, no wonder it look bad after being reduced to the size required to fit on screen.
First of all, thank you so much for replying.
Your link comparing resizing methods is very good, but relates to importing images directly into RH, or at the very least manually resizing each image in RH.
We work by importing our word documents into RH (is that not a very common method of using RH?). I was hoping that there was a way that I could import a word document with embedded images into RH without resulting in degradation of image quality, or alternatively needing to subsequently reimport each image separately. Otherwise, the import from word option is not really such a powerful function.
Weirdly enough, I have had success on occasion importing word documents with linked images into RH, even though it is not supported. I don't know what permutation of settings and clicking my heels allowed me to do that. But when it did work, the image quality was excellent. Is there some fundamental reason Adobe can't support import of linked documents?
The best way I have found of preserving image quality when importing word documents is by first resetting all images in Word to full size (using a macro?). Most images that have been reduced in size for a word document do not need resizing on a full screen in webhelp and so the reset to full size achieves the required size. The few that do, I resize using the ResizeTool. I was just hoping for an even more efficient method.
Sorry, I should have indicated it was more about resizing being the usual cause, be that direct or via Word.
Yes importing is common and whilst we do see people with problems, most people have success.
I don't know what the reason behind linked images is for sure, I suspect it is to do with the import being able to access the images from a network location.
I'll take another look at the thread later. Have to go out now.
Can you send me a Word document with some images?
One that imports cleanly without being expanded to full size.
One that imports cleanly only if expanded to full size.
One that will not import cleanly and has to be reworked in RoboHelp.
See the Contact page on my site. It's OK to attach the document to your email.
I have tested the documents you sent and what I find is that the documents where you reset the image size give a clear image, as expected. That said they would be way too large.
The smaller images are importing into RoboHelp with little difference in the quality they were in Word. Both had been significantly resized. If you resize in Word, they are then clear in Word but the same rescale in RoboHelp is poor. That is because in RoboHelp they were imported at the size seen in Word (already reduced) so when increased, the data is not in the file to give the required clarity.
One thing I did notice was the png images were importing as jpgs. At one time if you imported documents with pngs they would show as missing. The 902 service release changed that but I am not sure without further research whether they should import as pngs. At the moment they are importing as jpgs. What are you finding using the documents you sent me?
I also saved the png you had reset in Word as a png. I then resized that in SnagIt to 50% and whilst it could be increased back to size better than the image imported at reduced size, it was still unacceptable. Whilst I will find out the format in which RoboHelp should import the pngs, I don't think that will help too much. The key issue here seems to be the original size of the image, the fact that screenshots do not resize down too well and certainly not down to the degree you require ( around 50%).
Please confirm that in RoboHelp 9 you have the 902 service release applied?
Also please run a quick test to see if there is any difference according to whether you paste the image into Word or use Insert > Picture.
I don't understand what you mean when you write: "That is because in RoboHelp they were imported at the size seen in Word (already reduced) so when increased, the data is not in the file to give the required clarity." When are the images being increased in RH? - I was leaving them at the size they imported in (I never increase the size in RH, only decrease).
If I reduce the size of a capture in Word or Snagit to say 70% and insert it into a word doc and import it into RH, it is displayed in RH at 70% of the original size - and looks pretty bad (blurry, pixelated). But if I insert the capture in Word full size and then import into RH at full size and then reduce to 70%, it looks great - sharp, clear. In both cases, I am only reducing once and never increasing.
The examples I had sent you were using Insert>Picture. When I paste the pictures in instead, the image quality is slightly worse. And the quality is unacceptable not only when I reduce by 50% as in the examples I sent you, but even when I reduce by 70-75%.
I didn't have the 902 service release applied before, but I retested now that I do. The difference is that pngs now import as pngs and there is now no difference in image quality between imported pngs and gifs (I think they will only import as pngs if you check Allow PNG as a graphics format in the Word Options>Advanced in the Word doc).
Thanks for your help.
When I imported the reduced size images the quality was no different to when they were in Word. Both are bad in the reduced size documents before I start and are no worse in RoboHelp.
As I explained earlier, that level of reduction will lead to a severe reduction in clarity and I am seeing little or no difference between the reduced size images in Word and what RoboHelp shows.
I assume you meant you have also reduced TO 70-75% rather than BY that amount but even that will cause this issue. It is in the nature of the graphic rather than what RoboHelp is doing. That is witnessed by the fact the screen capture is no worse in Word which we all know is good at image reduction.
How bad is the difference you are seeing and are you viewing at 100%.
Hi, yes, I meant TO 70-75%.
The difference I'm seeing between the word doc and the webhelp/chm produced by rh is significant, and I am viewing at 100%. I am inserting here a screencap that shows the
image as generated by rh, next to the way it displays in the word doc. It is hard to see the difference since it is reduced so significantly in the forum here, but if you copy and paste it into a word doc and then reset to full size, I think the difference will be clear. Peter, I will also email you the screen cap comparing in case that somehow doesn't work.
Thanks again.
If you import the document pngnotresetinword.docx you are saying the image imports into RoboHelp as a PNG, correct?
I did a different test and can see what you are getting at but at the moment for reasons I cannot explain, the png is importing as a jpg so I would expect to see a difference.
Leave it with me for a while. Prompt me if I don't get back within 48 hours.
Sorry to come back but this is very important in the dialog I am having with Adobe. The PNG importing as a PNG is with the document you sent as above, not some other document or some other image.
I know about the setting.
It seems the cause of that is that the PNG in Word is transparent.
Please create a PNG that has no transparency, insert that into Word and see what happens in your webhelp.
It does seem like that is the problem, since when I snag my desktop
(which isn't transparent) it imports as a png. Similarly when I take
that initial screen cap in Word and "Recolor" the background, it also
then imports as a png.
BTW, though the image that is inserted in the RH page is the jpg in the
case of a transparency, the project imports both a jpg and png version,
and both show up in the files folder.
So when import now and the image comes in as a PNG, then the webhelp is OK, is that what you are saying?
yes, my screen cap looks ok in the webhelp. But what's strange is that I
tried retaking that screen capture of my desktop that before came in as
a png, and now it imports as a jpg. Similarly, when I resize that screen
cap in word, it then imports to RH as a jpg. I tried retaking that
screen cap of my desktop several times - always a jpg now! Should I send
you the rh file with the images?
If your screen capture is capturuing the image with transparency, then it is going to come in as a JPG. You need to capture the screen and then ensure there is no transparency.
Can we stock take now? It seems that if your images are PNGs with no transparency, they are importing OK and are OK in the webhelp. So it would seem you have a workflow that gives you what you want. Correct?
First of all, how do I ensure there is no transparency.
Second, I've experimented further and found that the determining factor
seems not to be transparency (unless that is somehow related to this)
but rather the resizing method. Screen caps that are full size import to
rh as pngs. Similarly, screen caps that were resized in snagit import to
rh as pngs. The image quality for both is very good.
Screen caps, however, that were resized in word (or by changing the
resolution in snagit or photoshop) import to rh as jpgs - with the
accompanying poor image quality.
The problem is that resizing the screen caps in snagit is not a good
option for the word documents - because the image quality in the doc is
quite poor (when viewed at a higher resolution)
So I still have no way of creating a word doc with images that can be
imported into RH while retaining the image quality.
I think you have answered your question. When Word resizes, the image has transparency. When RoboHelp saves the Word document as HTML, it has to use Word's Save As Web Page and the resized images then have this transparency meaning they have to come in as JPGs.
It may be that RoboHelp can engineer a solution but that would need a feature request and it will not help you in the short term.
I realise that this has not really got you a good workflow but at least the issues are understood.
Taking just the example you used, is that representative? Do you need to show, in that example, the whole ribbon?
Why are the resized gifs also being imported as jpgs?
I really don't understand how this isn't an issue for lots of RH users,
and a sufficiently serious one that Adobe would have seen fit to solve
it - how can RH be a serious option for generating online help from
print documentation when it "messes up" any resized image?
Perhaps this could be partially solved by supporting word docs with
linked images.
(Yes, we often like to show whole dialog boxes that require resizing.)
In any case, thanks for your help.
Because when Word resizes it is introducing transparency and transparency is something the import cannot handle, as explained. Where there is transparency, Word saves the image as a JPG, then hands it over to RoboHelp. I don't think there is anything Adobe can do but I will be taking that up with them.
I suspect that most people are working in RoboHelp to create their topics or accepting that the level of resizing required is just too great.
I just realised I misread your first sentence. I'll look again later but I thought they came in as gifs for me.
I imported your resized gif and confirm that too is coming in as a JPG. My guess is the issue is really to do with transparency and I have asked Adobe to confirm that.
It is the same issue. To convince yourself the format is converted to JPG by Word, save the gifnotresetinword document you sent me in Word as Web Page or Web Page filtered. Where you save it you will see a folder named gifnotresetinword_files and in it you will find a JPG. The file has been nowhere near RoboHelp at that point.
The image will show as reduced if you open the HTM version of the document as that size is what is applied in the file and that is what RoboHelp has to assume you want, the image to be the same size. Interestingly the JPG file is still full size.
Why Word changes the file format is something I cannot help you on, You will have to take that up with Microsoft.
I have spent some time saving Word documents in different ways with different resized images but every time the format is converted by Word to JPG. I turned off transparency in SnagIt, reduced the number of colours and so on.
Nothing but resetting the images to full size in Word seems to stop it converting the format to JPG.
There is a forum at http://windowssecrets.com/forums/ which is where I go for any Word problems. Maybe they can help. If they do, please post back. They will not be familiar with RoboHelp but there's no need for that. The help you require is to stop Word converting resized images to JPGs.
Hi there
Personally, I'd be doubtful there is much of anything Adobe can do to solve this issue. If I could offer an analogy here:
RoboHelp simply uses what Word has to offer it. So think of RoboHelp as a consumer and Word as a restaurant. The restaurant may have chicken or beef on hand along with a recipe for preparing a dish containing Chicken or Beef. Perhaps the dish is referred to as simply a meat burrito. So the consumer orders the recipe, but the chef decides to substitute goat meat instead of the Chicken or Beef. How can the consumer even know that the burrito contains anything different than Chicken or Beef? All they know is that they are given a burrito that has meat inside. Aside from complaining, there really isn't anything they can do to ensure that only Chicken or Beef ends up in the burrito, can they?
Likewise, RoboHelp only knows it's sucking in the content of a Word document. While it's prepared that Word may supply images, how is it to know that Word is pulling a switcharoo with the image format?
Cheers... Rick ![]()
To twist Rick's analogy, if the restaurant's meat supplier has delivered minced beef and someone walks in asking for a steak, there isn't much the restaurant can do. They can only work with what has been delivered. In the same way, authoring tools can only work with what Word has delivered.
It would take a developer with more detailed technical knowledge to advise whether or not there is any solution here. To the best of my knowledge though, all authoring tools will face this problem. Most offer free trials so try them on a non production machine.
Ayelet
I haven't read through the thread again but see if this helps.
Capture the same Word ribbon using SnagIt and save it as a PNG. I deselected Use Transparency but I am not sure that is the issue.
Now do a Save As in SnagIt and Resize the image to 50%. Make sure you deselect the Use Resampling check box. Save with a different file name.
Now insert both images into a Word document labelling them so that you know which is which.
Import the document into RoboHelp and you will see the image you reduced as remained as a PNG.
Generate WebHelp. Does the image that you resized still look good allowing for the massive reduction?
Please read again. I was talking about saving the original image using SnagIt, which I believe you said you have.
Use Resampling appears when I select the Resize option. Maybe it wasn't in your version. Enter "Resampling" into SnagIt's help search.
If you cannot find that, then maybe your version is too old.
I will send you a document with the two images.
I imported the doc you sent me to RH. And as you said, the image that
imported as a png looked good in RH9. The problem is, it doesn't look
good in Word (when I zoom in, as could be predicted, since it wasn't
resampled).
I had had the opposite experience - when I changed the resolution in
Snagit (essentially resampling - in my version of snagit, there is no
option called resampling) - the graphic then looked good in word, but
bad in RH (because it didn't import as a png ) It is strange that
resampling in snagit causes word to then convert the graphic when saving
to html as a jpg.
resampled).
to html as a jpg.
I think we have pretty much reached the end of the road then.
In Word at 100%, both images look the same.
If you zoom in Word, then only the image that Word resized down has the data in the file to zoom in. However that image will look poor in WebHelp because of the way that Word saves that file when saving as an HTML file, which is RoboHelp's start point. As already covered, RoboHelp has to take what Word gives it.
In RoboHelp, the file that Word handed over in the required format did not look poor because Word did not convert it to a JPG.
I can think of no other way to resolve this.
Hi, Guys! I am observing your conversation as I have a similar issue.
What I have noticed is that an image is processed by Photoshop (copied to a new PS tab from clipboard and saved as PNG) , it is converted to JPG by Robohelp when linkin a WORD document. But if an image has been saved as PNG w/o PS processing and uploaded to word document, it is not converted by RoboHelp. I use RH 902 and Word 2003. Can this be useful for you? What can be the reason for such behavior?
