Warp stabiliser in Premiere CS6 crashes
May 8, 2012 12:26 PM
Hi
Been playing with Premier CS6 since downloading yesterday.
I am getting regular crashes (windows tells me premiere has stopped working)
I add a clip onto he timeline, I add the warp stabiliser, analyise then play back - I go back to effects to change some warp settings, and the crash occurs.
Anyone else seeing this before I report to adobe
Chris Anderson
    May 8, 2012 12:38 PM   in reply to cjacs987654
    Definitely report it, but my best recommendation is to avoid Warp Stabilizer like the plague. It's really messed up in Pr CS6. It will cause project files to bloat uncontrollably (or, at least, until you delete the effect), the UI to slow to a crawl, and other not-so-niceties. It can work OK in smaller projects with very short clips, but anything more than a few seconds long that requires a fair bit of stabilization is, to quote Steven Tyler, like tap dancing on a landmine.
    Read this, too: http://blogs.adobe.com/toddkopriva/2012/05/memory-and-storage-tips-for -warp-stabilizer-and-3d-camera-tracker.html
    May 8, 2012 12:59 PM   in reply to cjacs987654
    Whether you use it in AE or Pr, I think the best advice is to do so in a project that is separate from your primary assembly project. That way, if things go pear-shaped, you don't lose all your other work, as well. Obviously, this means rendering out from that project, but it's a far better solution than crossing your fingers and hoping things don't implode.
    Don't get me wrong: what Warp Stabilizer can do is nothing short of amazing. But I think it really, really sucks that this time bomb shipped in the product. Users everywhere in all kinds of production venues are likely to use this effect, because it's there and it's REAL-TIME (after analysis, of course), but the potential side effects make this a really dangerous proposition.
    Caveat emptor.
    May 8, 2012 1:17 PM   in reply to cjacs987654
    Sorry to be the bearer of ill tidings! Out of curiosity, what footage type are you using? Have you tried a different flavor of media?
    May 8, 2012 1:53 PM   in reply to cjacs987654
    Colin's info is pretty good. Unfortunately, this is a similar problem to what has existed in stabiliser effects for nearly a decade. The main difference is that Warp Stabilizer actually does work VERY well (the final result, that is). But the project bloat and resource hogging that's required is seemingly not going away anytime soon. That's sort of the by-product of having to "fix it in post" I suppose. The best thing to do is only use it on the portions of clips that really need it. If you have a 30 second clip with a few bumps during the middle spanning a few seconds, then trim that portion of the clip out to a separate segment and apply the effect only right there.
    I used to use keyframes on older stabilizing effects and wondered for a while why it took days to render. I had the effect applied to a 5 minute clip but only keyframed to be active during 15 seconds. Similar to what's going on nowadays, although warp stabilizer is better and a bit faster anyway.
    Good luck! My best investment in solving shaky camera footage was a Steadicam Pilot, but that also costs a lot and takes more time to learn than it would to render out a few sequences with Warp Stabilizer.
    May 8, 2012 3:12 PM   in reply to cjacs987654
    Warp stabilizer was one of the reasons why I upgraded. Reading this is certainly worrying. I really can't jeopardize my projects beeing bloated. I really hope Adobe is working on improving, and providing stability fix. Thanks to C Jolly and C Brougham for describing the workarounds, so I'm not running my head in the wall - and don't understand why things slow down or crash. For now I will certainly wait adding stabilisation in my project to the last step in post.
    May 8, 2012 3:24 PM   in reply to carl nes
    FWIW
    My first test with Warp Stabiliser in CS6 went perfectly without a glitch. Result was outstanding.
    This thread has freaked me though ...and I am going to be very cautious how and when I use it next!!!
    Hopefully others will try and report back...positively...hopefully.... (to restore my confidence)
    CS6 WIN7
    May 8, 2012 3:34 PM   in reply to shooternz
    Please read this post on the After Effects team blog, it has to do with Warp Stabilizer and resources, and is applicable to Premiere Pro.
    May 8, 2012 6:18 PM   in reply to shooternz
    Clean CS6 install as well as Win7 Ultimate here.
    Put a 10sec clip into a new project timeline with Warp Stabiliser.  No crashes at all when messing with any of the settings.  Took about 2mins to analyze a 10sec clip on my Hexa-core i7.  Project file WITHOUT Warp Stabilizer on my clip was 3.5MB.  WITH Warp Stabilizer it jumped to 7.6MB....
    May 8, 2012 7:23 PM   in reply to cjacs987654
    I'm still on 5.5, but I used Warp Stabilizer on a 4:45 long clip of DSLR footage of driving up a mountain highway for fun, and it had no problems handling it. This was in AE 5.5, Mac Pro with GTX 285 and 32GB of RAM, media on an 8-disk RAID6 of HDDs. I'm wondering if your use of SSDs for the media could be causing problems.
    As soon as I get CS6 loaded, I'll try it in Pr and AE again.
    May 8, 2012 7:52 PM   in reply to Pcenginefx
    Now you're seeing it...
    Here's where I realized something was amiss: I had a less than two minute sequence, all hand-held footage, that I wanted to stabilize. There were only about 6 or 7 clips in the sequence, and no other effects. I dropped Warp Stabilizer on the clips, and let it analyze... it took awhile, but I was OK with that. When it was done, despite Warp Stabilizer being a GPU-accelerated effect (after analysis), most of the clips were red bar. Hmm...
    So, thinking maybe I just needed a restart, I saved my project. And I waited. And I waited some more. About a minute later, my project final stopped saving. Weird. So I tried to do something in the Timeline... and it was like running through a tar pit.
    I killed off Pr, and went to check my project file... it was over 50MB... for a 7 clip, less than two minute sequence. That's a problem. When I finally got the project open again, I purged all the Warp Stabilizer instances, and saved a new copy of the project. This time, it was about 1.3MB. That is a HUGE difference, all attributed to Warp Stabilizer. Needless to say, I'm very reluctant to Warp Stabilizer do its damage to my project files, regardless of how good the output is.
    So, let this be a cautionary tale. If you think you'll only need to stabilize a few seconds here or there, or you're totally cool with working in a completely different project to stabilize your footage (though look how well that worked for me), go for it. Fair warning...
    May 19, 2012 7:44 PM   in reply to Colin Brougham
    I just came across this and need to go test.
    Two suggestions that I have seen mentioned elsewhere (not my ideas):
    1) Using dynamic links and running Warp Stabilizer in After Effects, (hopefully no bloat there) and
    2) Applying Warp Stabilizer in a separate project, then rendering out a clip to import into your main project.
    Obviously the first solution is a little more elegant.
    More after testing.
    Best,
    Michael
    May 21, 2012 11:38 AM   in reply to cjacs987654
    Hello Chris,
    I hope things have been going more smoothly for you.
    I wanted to see if you can provide me with some more details. You said " I go back to effects to change some warp settings, and the crash occurs."
    Can you tell me what settings you changed? Also, what camera did the media come from?
    Thanks in advance!
    May 22, 2012 1:38 PM   in reply to cjacs987654
    Hi Chrish,
    Thanks for the info. I should have asked this before but can you tell me the resolution and frame rate? Thanks for your feedback.
    Jun 10, 2012 11:51 AM   in reply to petergaraway
    I noticed that warp stabilizer in Pr uses only one core (of 8 in my system). Not sure if it used more cores in Ae, just noticed by coincidence that in Pr it uses only one core.
    Oct 1, 2012 8:50 PM   in reply to cjacs987654
    I too am disapointed that warp stabilizer doesn't work well in PP CS6. I send my files to AE to do it and have had no problems, however, that can become very tiresome. I'm a journalist and I have to turn around material quickly and on most projects I can't afford to play around and send every item to AE.
    Thankfully, rolling shutter repair works fine in PP CS6. I shoot on a Canon T3i, most commonly 1080p 30fps.
    Mar 6, 2013 10:26 AM   in reply to Dumac1989
    I'm a bit late to the party but I've had an adventure with Warp Stabilzer.
    Needing to correct some MTS HD 60fps footage for shakes, I was delighted to find out Pr now comes with WS, borrowed from AE. My 23 second clip needed help, for sure, but it was not an impossible task. I waited about 8 minutes for WS to analyze the clip. Then checked out its first result: smoother but almost as bad as the raw footage. So I set the dropdown to No Motion which is supposed to lock down the camera viewpoint. Got a warning that I needed to change another setting to Stabilize Only, so did that. The result? All black. Nothing. Whoa... Now I've seen demo clips of WS online and the before and afters look pretty good. The befores are shaking more than my clip. Why doesn't WS work?
    Meanwhile, I found out about Mercalli V2 from the Adobe forums, so I installed the demo. Analysis took less than a minute. The result? Perfect! Now I'm really scratching my head. How could AE's (now Pr's) WS fail completely and Mercalli succeed? BTW, Mercalli V2 costs $250.
    The purpose-built system I'm using consists of i7 3.4 ghz CPU, 16 gb RAM, SSD video drive, Win 7 Pro 64-bit, GTX 660 card 2 gb DDR5 RAM (MPE enabled and running).
