Photoess
What is error message 106?
May 8, 2012 12:54 PM
This message popped up at the end of my attempt to download a trial version of Elements 10.  How do I resolve it?
    May 8, 2012 1:04 PM   in reply to Photoess
    Where are you trying to download the install files too?  Which operating system are you using?
    May 8, 2012 2:10 PM   in reply to Photoess
    Ok Photoess it appears you are installing the software.  To close the Bridge process you will want to go to your Task Manager and locate the Bridge process and end it.  You will then be able to complete your installation of Photoshop Elements successfully.
    May 8, 2012 2:29 PM   in reply to Photoess
    The default location is your User folder.  I would recommend checking there.  Otherwise is there a different place you might have chosen to download the install files too?
    May 8, 2012 2:52 PM   in reply to Photoess
    From the information provided you need to run one of the installers and close the Bridge process via your task manager.  Your install process should then proceed normally after that.
