Dreamweaver CS5.5 Crashes Upon Image Insertion
May 8, 2012 11:36 AM
Tags: #dreamweaver #crash #images
Hi there,
I am using Dreamweaver CS5.5 on Windows 7 64bit and I am having an issue with inserting images visually through the Insert > Image menu option and the common menu bar.
I can browse through explorer to the image I want, I can select the image and the moment I do Dreaweaver crashes. This also happens when defining background (or any) images in CSS styles.
However, when drag an image from the Files Panel to Code View, it works perfectly with no issue. This just literally started happening and I have no possible explanation for it unless it is a windows explorer issue of some kind. However, I am not having any image opening problems with any other programs through explorer.
I have also tried deleting the Dreamweaver Cache to no avail.
I would appreciate if anyone has any ideas or suggestions?
Martin
    May 8, 2012 12:28 PM   in reply to Snarky7D
    Just fishing Martin, but is your site defined correctly?
    May 8, 2012 12:46 PM   in reply to Snarky7D
    Does is occur In all sites?   All pages?  Or just one?
    Can you show us a link to a page that crashes?  Can you also show us a link to the image you're trying to insert?
    Nancy O.
    Alt-Web Design & Publishing
    Web | Graphics | Print | Media  Specialists
    http://alt-web.com/
    http://twitter.com/altweb
    http://alt-web.blogspot.com/
    May 8, 2012 2:18 PM   in reply to Snarky7D
    OK.  Can you work without crashing in Code View?
    Nancy O.
    May 8, 2012 3:14 PM   in reply to Snarky7D
    Well, this has me stumped.  You said in an earlier post, you deleted DW Cache.
    Did you also delete your personal config folder?
    http://forums.adobe.com/thread/494811
    Nancy O.
    Sep 18, 2012 2:52 AM   in reply to Snarky7D
    Also having the same problem as Martin but also crashes when I drop and drag from the files panel. Am using Mac Lion. Have updated software etc. etc. This makes Dreamweaver unusable for me. Will have to use Cloud CS6 - not acceptable!!!!
