TrekkerRML
CS6 64 hangs-why?
May 8, 2012 8:17 PM
Tags: #cs6_crash #cs6_opening_problem
Just installed Photoshop CS6 Extended on two 64 bit Windows 7 machines. One went fine--a clean install on a workstation with no prior CS versions.
Second machine, a laptop,  not so good. The 64 bit version hangs as soon as I try to open a file, even using File > New. The program is totally hung and nonresponsive at that point. But the 32 bit version works fine.
Both machines are running 64 bit Win 7, SP1, autoupdated. The second machine had Photoshop 7 and Photoshop Elements 8 still present when I first installed CS6. When the 'hang' first happened, I uninstalled both, and then reinstalled CS6. Problem persisted. Unistalled and reinstalled CS6 again after reboot. Problem persisted.
VERY irritating, Adobe.
    May 8, 2012 10:24 PM   in reply to TrekkerRML
    Which application are you talking about?
    This forums is for complete suite  , you should discuss on the product specific forum like Illustrator , Indesign etc.
    May 9, 2012 4:15 AM   in reply to TrekkerRML
    Update your graphics driver.
    Mylenium
    May 9, 2012 5:49 AM   in reply to TrekkerRML
    Hey TrekkerRML,
    During the CS 5.5 install days, Adobe created a CS4/5/5.5 cleaner application that removed all remnants of Suite installs so that there would be no complications with payloads & installs.
    For me when upgrading back then, the cleaner tool(s) worked.
    I think they're still available on the Knowledge Base or whatever the support docs area is now called.
    It is a frustrating process. I'm getting my discs today and hope to not experience these issues again.
    I also wrote a blog post about installing CS5.5. It's methods might still be relative.
    http://dickkirkland.com/blog/2011/05/09/whos-got-time-to-install-cs5-5 /
    Good luck.
    Sincerely,
    Dick
    May 9, 2012 2:58 PM   in reply to TrekkerRML
    Do you receive an actual installation error or are you having problems when you launch the program itself?  The program could have installed properly but other factors maybe contributing to the behavior you are currently experiencing.
    May 9, 2012 3:26 PM   in reply to TrekkerRML
    Moving this discussion to the Photoshop General Discussion forum.  The users in this forum can assist you with difficulties you are facing with performance issues of the software itself.
    May 9, 2012 3:31 PM   in reply to TrekkerRML
    Did you update from Microsoft (mistake) or from ATI's website?
    May 9, 2012 3:33 PM   in reply to TrekkerRML
    Time to try the Event Viewer.  Check Help in OS on how to load.
    Look for errors in Applications.  See what the Faulting Module says.
  • Noel Carboni
    Dec 23, 2006
    May 9, 2012 4:36 PM   in reply to Chris Cox
    Since it's a Mobility chipset we can assume it's probably a laptop.  The rules change for laptops; one usually has to update drivers from the laptop maker's web site, and the choices are often much more limited than at ATI.com.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 9, 2012 4:39 PM   in reply to TrekkerRML
    Do you have any network devices defined that are not present at the moment (e.g., a mapped network drive that's only there when you're at work with the laptop), or a printer that was once there but isn't there any longer?
    Have you tried leaving it alone at the "hung" state for a long time?
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 9, 2012 5:28 PM   in reply to TrekkerRML
    TrekkerRML wrote:
    Not clear why a drive connect should affect 64 bit PS vs 32 bit, which works fine.
    They have separate preferences.  Have you tried clearing your preferences to defaults by pressing Control - Shift - Alt during a cold start of the 64 bit Photoshop?
    -Noel
    May 10, 2012 6:58 AM   in reply to TrekkerRML
    Wow, crazy all of this you're having to go through.
    Along with the Cleaner Tool(s), I make it a habit of going through and actually wiping out the prefs (mentioned above) along with any other Adobe related files.
    These can often hang around in places you'd never think to look, like "AppData/Roaming, Local, Low".
    There are also specific ARM files that track what's installed, registered, etc.
    One more question, is the installation being carried out from a disc?
    Is it being installed from a download?
    In that blog post I mentioned, one time a tech. rep advised me to copy the contents of all directories of install discs onto the local drive of the machine.
    There was a bug with payloads not being able to be accessed properly when installing from a set of directories on a disc.
    Strange that you never recieved errors though.
    On the last upgrade cycle, these were apparent, but may be hidden now.
    There were even support docs citing these codes.
    Are you using Windows Home Premium 64-Bit or Pro?
  • Noel Carboni
    Dec 23, 2006
    May 10, 2012 8:45 AM   in reply to TrekkerRML
    It occurs to me that the latest version of your display driver may be broken.
    You might want to see if an older version is available (I know ATI makes all the old releases available).
    If you can, remove the latest display driver completely, and try installing Catalyst 12.2.  I found that release very stable.
    -Noel
    May 10, 2012 8:55 AM   in reply to Noel Carboni
    I guess the fact that there are no errors on the install and the first launch goes o.k. may point to a video driver issue.
    I would try the Catalyst suggestion Noel mentioned.
    I had to do this once for something else.
    I believe in order to obtain the driver for older cards, you have to install the full Catalyst product suite vs. trying to find an older driver that's a standalone.
    Mar 21, 2013 6:07 PM   in reply to dickkirkland
    I am having the identical problem, started just a couple of weeks ago.  I did have a bad mouse driver that was causing problems with a variety of programs, including Lightroom, but all except Photoshop CS6 were fixed when I backed that out.
    I've checked the GPU settings, the ATI driver for my video card, uninstalled and reinstalled.  If I use PSCS6 in 32-bit mode, it works fine.  Not in 64-bit mode.  Running WIndows 7 Pro w/SP1, 64-bit.  I haven't seen a solution for this problem posted -- is there one?
  • Noel Carboni
    Dec 23, 2006
    Mar 21, 2013 7:55 PM   in reply to LitewriterRS
    ATI drivers have been horrendous lately.
    The most recent release that actually works with Photoshop is Catalyst 12.8.  They haven't been able to release drivers that work since then in over 6 months.
    I'm currently running Catalyst 13.3 beta 3.  This build actually seems to run pretty well with Photoshop CS6, but I haven't put a lot of miles on it yet.
    -Noel
    Mar 22, 2013 12:32 PM   in reply to TrekkerRML
    Chris, yes, a laptop: HP Envy 17.
    It should not be an issue with a fairly current 17" laptop, but what is your display resolution set to?
    Good luck,
    Hunt
Bookmarked By (1)
