RaineandhorneITteam
Cant Open illustrator Files Memmory Error
May 8, 2012 11:34 PM
Firstly I have researched this online and foudn many postings dating back 3 years with no resoultion or even a work around. I dont normally like to post on these forums but there isnt anything else to try.
Firstly computer specs
I7 CPU
16 GB DDR3 RAM
250 SSD drive
1tb sata drive
Currently Virtual Memmory is set to be able to use 16 gb of addition ram from the hard drive.
So I had Adobe Design Premium trail 5.5 installed, I then removed then ran teh adobe clean up tool, ran CC cleaner to clear the registry and re installed CS5.5 full version with lisence. The issue happens on both version of the install.
This is also a new computer and only 2 weeks old, no font manager, no extra fonts.
When ever various files are opened ranging from 10 mb - 40 mb in illustrator, it instanly comes up with an out of memmory error. However I have watched this happen and monitored the memmory use whilst it is happening and the memmory in use was only 2.2 GB total on the machine. THe hard drive activity is minimal as well.....
I have tried this on the above computer, then tried it on teh same spec computer running Design Standard, then on a laptop with less memory ( 4gb) running master collection and also a virtual machine i set up that had 8 gb ram running Design Premium all 5.5.
I had the same error on all 4 machines when opening a 20 mb file, i have also tried several other files ( 6) and none of them work, however they did used to work on CS5.
There are apparantly no work arounds or fixes for this and its extremely irritating as you know what marketing and design people can be like ! Why has adobe not released a fix for this after 3 years and does any one know of a work around or fix to do this. Comlexity is not an issue in the fix.
cheers
daniel
    May 9, 2012 4:01 PM   in reply to RaineandhorneITteam
    The memory use you quoted is about what is available to AICS5.5 and earlier. It is a 32 bit application and as such can only access about 3 GB of RAM memory. Anything above that is not used; no matter how much you have. That said, what is the content of the files in question? How many anchor points? Linked or embedded raster images? Saved with PDF compatibility on or off? More information is needed to help track down what is happening.
