links not working when clicking (code included)
May 8, 2012 11:20 AM
Tags: none (add) #3.0 #swf #actionscript #event #code #flash_cs5 #actions #urlrequestOk im totally new to AS so i will do best to describe issue i am running into.....
Have a cover photo created in PS,and on photo, there is text, which when click should open pdf file specified.....well when i hover over, and click....it doesnt go anywhere....(example below) THX for any responses and assistance.
EX: this would be the cover photo
REPORT
Analysis (this should have a sub menu of PDF's which it does, but when click on the pdf's refrenced, it doesnt go anywhere)
Link 2 (PDF)
Link 3 (PDF)
Link 4 (PDF)
Link 5 (same as Analysis)
Link 6 (PDF)
ect ect...
CODE BELOW....
import flash.net.URLRequest;
import flash.events.MouseEvent;
import flash.events.Event;
//init menu links
var link_1:Object = this.getChildByName( 'MenuLinkMC_1' );
var link_2:Object = this.getChildByName( 'MenuLinkMC_2' );
var link_3:Object = this.getChildByName( 'MenuLinkMC_3' );
var link_4:Object = this.getChildByName( 'MenuLinkMC_4' );
var link_5:Object = this.getChildByName( 'MenuLinkMC_5' );
var link_6:Object = this.getChildByName( 'MenuLinkMC_6' );
var link_7:Object = this.getChildByName( 'MenuLinkMC_7' );
var link_8:Object = this.getChildByName( 'MenuLinkMC_8' );
var link_9:Object = this.getChildByName( 'MenuLinkMC_9' );
var _close:Object = this.getChildByName( 'closeMC' );
this._close.addEventListener( MouseEvent.CLICK, quit );
var sub_menu_notes_slide:Object = this.getChildByName( 'SubMenu_NotesSlideMC' );
var sub_menu_discussion_slide:Object = this.getChildByName( 'SubMenu_DiscussionSlideMC' );
//set url addresses
var url_link_1:URLRequest = new URLRequest( 'PDF_FILES/1. MD&A Introduction.pdf' );
var url_link_2:URLRequest = new URLRequest( 'PDF_FILES/9. Independent Auditors\' Report.pdf' );
var url_link_3:URLRequest = new URLRequest( 'PDF_FILES/10. Balance Sheets.pdf' );
var url_link_4:URLRequest = new URLRequest( 'PDF_FILES/11. Statements of Revenues, Expenses and Changes in Fund Net Assets.pdf' );
var url_link_5:URLRequest = new URLRequest( 'PDF_FILES/12. Statements of Cash Flows.pdf' );
var url_link_6:URLRequest = new URLRequest( 'PDF_FILES/13. Note 1 - Summary of Significant Accounting Policies.pdf' );
var url_link_7:URLRequest = new URLRequest( 'PDF_FILES/31. Glossary of Terms.pdf' );
var url_link_8:URLRequest = new URLRequest( 'PDF_FILES/EOY Audited Financials - FY2011 with blue links.pdf' );
var url_link_9:URLRequest = new URLRequest( 'http://www.cpsenergy.com' );
//run subroutines
noMenu();
set_link( link_1, url_link_1, sub_menu_discussion_slide );
set_link( link_2, url_link_2, null );
set_link( link_3, url_link_3, null );
set_link( link_4, url_link_4, null );
set_link( link_5, url_link_5, null );
set_link( link_6, url_link_6, sub_menu_notes_slide );
set_link( link_7, url_link_7, null );
set_link( link_8, url_link_8, null );
set_link( link_9, url_link_9, null );
//subroutines
function set_link( linkObject:Object, linkURL:URLRequest, optMenu:Object ):void {
linkObject.addEventListener( MouseEvent.CLICK, click_link );
linkObject.addEventListener( MouseEvent.MOUSE_OVER, mouse_over_link );
if ( optMenu != null ){
this.setChildIndex( MovieClip( optMenu ), 9 );
linkObject.addEventListener( Event.ENTER_FRAME, slide_sub_menu );
function click_link( evt:MouseEvent):void {
navigateToURL( linkURL, 'File.browseForOpen()' ); <-----(note: should this be set to "_blank" ?)
function mouse_over_link( evt:MouseEvent ):void {
linkObject.mouseChildren = false;
linkObject.buttonMode = true;
linkObject.useHandCursor = true;
function slide_sub_menu( evt:Event ):void {
if ( optMenu.hitTestPoint( mouseX, mouseY, true )) {
optMenu.nextFrame();
} else {
optMenu.prevFrame();
function quit( evt:MouseEvent ):void {
fscommand("quit", "");
function noMenu():void {
var NoMenu:ContextMenu = new ContextMenu();
NoMenu.hideBuiltInItems();
this.contextMenu = NoMenu;
---------------------------------------------------------------------- ---------------------------------------------------AND
//init sublinks
var sublink_1:Object = this.getChildByName( 'SublinkMC_1' );
var sublink_2:Object = this.getChildByName( 'SublinkMC_2' );
var sublink_3:Object = this.getChildByName( 'SublinkMC_3' );
var sublink_4:Object = this.getChildByName( 'SublinkMC_4' );
var sublink_5:Object = this.getChildByName( 'SublinkMC_5' );
var sublink_6:Object = this.getChildByName( 'SublinkMC_6' );
var sublink_7:Object = this.getChildByName( 'SublinkMC_7' );
var sublink_8:Object = this.getChildByName( 'SublinkMC_8' );
var sublink_9:Object = this.getChildByName( 'SublinkMC_9' );
var sublink_10:Object = this.getChildByName( 'SublinkMC_10' );
var sublink_11:Object = this.getChildByName( 'SublinkMC_11' );
var sublink_12:Object = this.getChildByName( 'SublinkMC_12' );
var sublink_13:Object = this.getChildByName( 'SublinkMC_13' );
var sublink_14:Object = this.getChildByName( 'SublinkMC_14' );
var sublink_15:Object = this.getChildByName( 'SublinkMC_15' );
var sublink_16:Object = this.getChildByName( 'SublinkMC_16' );
var sublink_17:Object = this.getChildByName( 'SublinkMC_17' );
var sublink_18:Object = this.getChildByName( 'SublinkMC_18' );
//set link names dynamic text
sublink_1.SublinkNameDT.text = 'Note 1 - Summary of Significant Accounting Policies';
sublink_2.SublinkNameDT.text = 'Note 2 - Cash, Cash Equivalents and Investments';
sublink_3.SublinkNameDT.text = 'Note 3 - Disaggregation of Current Receivables and Payables';
sublink_4.SublinkNameDT.text = 'Note 4 - Capital Assets';
sublink_5.SublinkNameDT.text = 'Note 5 - Revenue Bond and Commercial Paper Ordinances Requirements';
sublink_6.SublinkNameDT.text = 'Note 6 - Revenue Bonds';
sublink_7.SublinkNameDT.text = 'Note 7 - Commercial Paper and Related Revolving Credit Agreement';
sublink_8.SublinkNameDT.text = 'Note 8 - Flexible Rate Revolving Note';
sublink_9.SublinkNameDT.text = 'Note 9 - Employee Pension Plan';
sublink_10.SublinkNameDT.text = 'Note 10 - Other Postemployment Benefits';
sublink_11.SublinkNameDT.text = 'Note 11 - Other Obligations and Risk Management';
sublink_12.SublinkNameDT.text = 'Note 12 - Other Financial Instruments';
sublink_13.SublinkNameDT.text = 'Note 13 - Lease-Leaseback';
sublink_14.SublinkNameDT.text = 'Note 14 - South Texas Project';
sublink_15.SublinkNameDT.text = 'Note 15 - Commitments and Contingencies';
sublink_16.SublinkNameDT.text = 'Note 16 - Leases';
sublink_17.SublinkNameDT.text = 'Note 17 - Pollution Remediation Obligation';
sublink_18.SublinkNameDT.text = 'Note 18 - Subsequent Events';
//set url addresses
var url_sublink_1:URLRequest = new URLRequest( 'PDF_FILES/13. Note 1 - Summary of Significant Accounting Policies.pdf' );
var url_sublink_2:URLRequest = new URLRequest( 'PDF_FILES/14. Note 2 - Cash, Cash Equivalents and Investments.pdf' );
var url_sublink_3:URLRequest = new URLRequest( 'PDF_FILES/15. Note 3 - Disaggregation of Current Receivables and Payables.pdf' );
var url_sublink_4:URLRequest = new URLRequest( 'PDF_FILES/16. Note 4 - Capital Assets.pdf' );
var url_sublink_5:URLRequest = new URLRequest( 'PDF_FILES/17. Note 5 - Revenue Bond and Commercial Paper Ordinances Requirements.pdf' );
var url_sublink_6:URLRequest = new URLRequest( 'PDF_FILES/18. Note 6 - Revenue Bonds.pdf' );
var url_sublink_7:URLRequest = new URLRequest( 'PDF_FILES/19. Note 7 - Commercial Paper.pdf' );
var url_sublink_8:URLRequest = new URLRequest( 'PDF_FILES/20. Note 8 - Flexible Rate Revolving Note.pdf' );
var url_sublink_9:URLRequest = new URLRequest( 'PDF_FILES/21. Note 9 - Employee Pension Plan.pdf' );
var url_sublink_10:URLRequest = new URLRequest( 'PDF_FILES/22. Note 10 - Other Postemployment Benefits.pdf' );
var url_sublink_11:URLRequest = new URLRequest( 'PDF_FILES/23. Note 11 - Other Obligations and Risk Management.pdf' );
var url_sublink_12:URLRequest = new URLRequest( 'PDF_FILES/24. Note 12 - Other Financial Instruments.pdf' );
var url_sublink_13:URLRequest = new URLRequest( 'PDF_FILES/25. Note 13 - Lease-Leaseback.pdf' );
var url_sublink_14:URLRequest = new URLRequest( 'PDF_FILES/26. Note 14 - South Texas Project.pdf' );
var url_sublink_15:URLRequest = new URLRequest( 'PDF_FILES/27. Note 15 - Commitments and Contingencies.pdf' );
var url_sublink_16:URLRequest = new URLRequest( 'PDF_FILES/28. Note 16 - Leases.pdf' );
var url_sublink_17:URLRequest = new URLRequest( 'PDF_FILES/29. Note 17 - Pollution Remediation Obligation.pdf' );
var url_sublink_18:URLRequest = new URLRequest( 'PDF_FILES/30. Note 18 - Subsequent Events.pdf' );
//run subroutines
set_sublink( sublink_1, url_sublink_1 );
set_sublink( sublink_2, url_sublink_2 );
set_sublink( sublink_3, url_sublink_3 );
set_sublink( sublink_4, url_sublink_4 );
set_sublink( sublink_5, url_sublink_5 );
set_sublink( sublink_6, url_sublink_6 );
set_sublink( sublink_7, url_sublink_7 );
set_sublink( sublink_8, url_sublink_8 );
set_sublink( sublink_9, url_sublink_9 );
set_sublink( sublink_10, url_sublink_10 );
set_sublink( sublink_11, url_sublink_11 );
set_sublink( sublink_12, url_sublink_12 );
set_sublink( sublink_13, url_sublink_13 );
set_sublink( sublink_14, url_sublink_14 );
set_sublink( sublink_15, url_sublink_15 );
set_sublink( sublink_16, url_sublink_16 );
set_sublink( sublink_17, url_sublink_17 );
set_sublink( sublink_18, url_sublink_18 );
//subroutines
function set_sublink( sublinkObject:Object, sublinkURL ):void {
sublinkObject.addEventListener( MouseEvent.CLICK, click_sublink );
sublinkObject.addEventListener( MouseEvent.MOUSE_OVER, mouse_over_sublink );
sublinkObject.addEventListener( MouseEvent.MOUSE_OUT, mouse_out_sublink );
function click_sublink( evt:MouseEvent):void {
navigateToURL( sublinkURL, '_blank' );
function mouse_over_sublink( evt:MouseEvent ):void {
sublinkObject.mouseChildren = false;
sublinkObject.buttonMode = true;
sublinkObject.useHandCursor = true;
sublinkObject.gotoAndStop( 'On' );
function mouse_out_sublink( evt:MouseEvent ):void {
sublinkObject.gotoAndStop( 'Off' );
