cfqueryparam truncates values even when scale is specified
May 2, 2012 11:42 AM
Tags: #scale #coldfusion_9 #cfqueryparam #cf_sql_decimal
I'm connecting ColdFusion 9.0.1 with MySQL 5.5 using the MySQL 5.1 ODBC connector. I have a table with a field defined as DECIMAL(11,2) intended to store currency amounts.
When I use <cfqueryparam cfsqltype="cf_sql_decimal" scale="2" value="#nValue#"> to insert a value in that field, the value stored in the parameter (when I show debug output on the parameters after the query is run) is correct and not truncated, but the value stored in MySQL is truncated (not rounded).
I know this is probably a driver issue, but I'm hoping that this forum will be able to help me troubleshoot the problem.
    May 2, 2012 6:42 PM   in reply to Oregon Will
    I rarely use ODBC anymore. But it works as expected with a jdbc connection. This inserts "11.57":
                          <cfqueryparam cfsqltype="cf_sql_decimal" scale="2" value="11.565">
    Aside from switching to jdbc
    1) Can you dump the generated sql? What is the value of #nValue# and the actual value inserted into the table?
    2) It should not make a difference, but any change if you temporarily use hard coded values? ie INSERT INTO ... VALUES (11.56) OR use cf_sql_numeric?
    May 9, 2012 8:28 AM   in reply to Oregon Will
    What is the value? How is it truncated?
    May 9, 2012 11:58 PM   in reply to Oregon Will
    The issue arises perhaps from incorrect syntax. Try this:
    <cfquery datasource="telcomm" name="insert_leftover_adj">
    INSERT INTO bill_warehouse(keyBill,keyBillItem,keyProgram,nAmount,sDescription)
    VALUES(<cfqueryparam cfsqltype="cf_sql_integer" value="#Bill.keyBill#">,
       <cfqueryparam cfsqltype="cf_sql_integer" value="#qryPoolItem.keyBillItem#">,
       #keyProgramTech#,
       <cfqueryparam cfsqltype="cf_sql_decimal" scale="2" value="#qryLeftover.nPool#">,
       'Adjustment ...'
    </cfquery>
    May 10, 2012 7:28 AM   in reply to Oregon Will
    Oregon Will wrote:
    The INSERT INTO...SET syntax may not be standard, but it is valid syntax for MySQL. I use the INSERT INTO...SET syntax because it is much easier to read, much easier to make sure that the field-value assignments are correct. Notice that the query works fine when the parameter is passed in with cfsqltype="cf_sql_double" and when the value is hard-coded.
    Sorry. No need to explain. I should have said non-standard instead of incorrect. The question remains: does the version with standard SQL work? If so, then we will only have to look into why the MySQL syntax leads to truncation.
