Shotup77CH
CS6 Trial German Sequence Presets issue
May 7, 2012 5:56 PM
Hi
I just downloaded and installed the german Premiere CS6 Trial Version. When I try to create a new sequence, I have only PAL and DVCPro Presets available. No DSLR or others are available. I remember, that there was something similiar with an earlier Trial from CS5.
What can I do?
    May 7, 2012 5:58 PM   in reply to Shotup77CH
    Start a new project and open it. Close the project and Pr. Relaunch Pr, and you should be good to go. The presets that utilize licensed codecs typically need to be serialized to your install, which is done after an initial launch.
    Should that not work, post back...
    May 8, 2012 2:46 AM   in reply to Shotup77CH
    Download the trial again.
    May 9, 2012 11:38 AM   in reply to Shotup77CH
    Are you connected to the internet when you installed / launched Premiere?  The installer allows for an installation to complete on a system that does not have internet access but you will not get any 'protected content' files like the DLSR presets enabled until the system is connected to the internet (to execute in trial mode).
