Locked
1
Copy Highlighted Text in Pdf file
Guest
Sep 09, 2011 Sep 09, 2011
Hi everyone,
Recently I downloaded the Adobe Reader X (version 10.0). This version allows me to highlight text (in yellow colour). However, If I want to copy a highlighted block of text (for instance to paste into a Word document), I am not able to do this. When I select the highlighted text and click on the right mouse click, it doesn't give me the opportunity to copy this text. Therefore, I was wondering whether I can copy the highlighted text in another way?
Thanks in advance for a reply.
Kind regards,
Sleighon
81.9K
Sep 22, 2011 Sep 22, 2011
Same problem here. This is a nuisance.
Adobe Employee ,
Sep 23, 2011 Sep 23, 2011
Select the text (not the highlight) and press Ctrl+C.
Sep 30, 2011 Sep 30, 2011
I have this problem too. The problem is that I CAN'T "Select the text (not the highlight)". If I have a paragraph of text highlighted in a PDF and the selection tool enabled, when I mouse over the highlighted text my cursor changes from a standard cursor to four-sided arrow. If I click on the block of highlighting, the block itself is selected (not the text beneath it).
So, to repeat, how does one select the text if it is already highlighted?
Which options did you get?
Oct 07, 2011 Oct 07, 2011
Agreed. More than a nuisace, hindering productivity. Any solutions appreciated.
May 09, 2012 May 09, 2012
It's not very practical, but I got around this by selecting a larger area than the highlighted text I wanted to copy, i.e. starting before the part I wanted and finishing after it. Then pasting the whole lot, and deleting the parts I didn't want after pasting it.
I don't understand why it's not possible just to copy highlighted text though, it seems ridiculous to remove the option!
Jan 19, 2013 Jan 19, 2013
I don't understand why it isn't possible to copy highlighted text either.  The suggestion to expand the area beyone the highlighted section is great but, again, it is inconvenient and hampers productivity.  Simply put, it is a nuisance in adition to being stupid.  Not a characteristic that is often attributed to Adobe products!!!
I do not see what the problem is...
  1. highlight some text
  2. right-click on the document and click Select Tool
  3. select the (highlighted) text you want to copy
  4. Ctrl+C to copy
  5. paste it anywhere, e.g. in Word
Jan 22, 2013 Jan 22, 2013
It seems you don't understand where the problem is. APPLY a highlight to the text, which is to say select it and use the Tools function to highlight the text. The text you've highlighted now remains yellow. Now, choose the same chunk of text you've highlighted and go to Edit, under which you will notice that the Copy function has been disabled. Once a section of text has been Highlighted the Copy function is disabled for that section of text. This makes no sense at all and is a considerable impediment to productivity for folks who use these functions together on a regular basis. Even with Adobe Pro XI this issue has not been resolved, when simple programs like Kindle apps get it right.
Interesting problem. I think it's because annotations always see clicks in preference to the underlying page. Almost always.
It's quite easy to select text which begins outside or ends outside a highlighted section.
Click outside the highlight (or just before the beginning, or just after the end).
Release the mouse (this isn't a drag action). The flashing cursor should appear.
Now Shift+click inside the highlight. Text between the two points can be copied.
I noticed this because for me it's a faster more accurate way of selecting text which works in almost all apps, so I often use it.
Yeah, that's one way to get around a flaw in the program, but it's inconvenient as it requires deleting the additional text when pasting. Also, if you want to copy a chunk of text that is embedded within a longer highlighted section it's even more of a nuisance.
Indeed, I do not understand what the problem is.  When I tested it yesterday (using Reader 11.0.1) I actually took some screenshot, but I didn't think it necessary to post them.  I'll do it now.
Opening a random PDF from My Documents
then highlight some text
apply the Select Tool (using right-click)
select the same highlighted text
copy (Ctrl+C) then paste it into an empty Word document
Ok, the highlighting did not get copied over - is this the problem?
Perhaps the problem is that I use Mac, but this doesn't work with my system. Any highlighted text that I select cannot be copied. The copy function is disabled with any highlighted text. I don't know if this has any connection, but when I right click on highlighted text there isn't a Select Tool option. Still, when my cursor is in Select Tool mode (via the tool bar), and I select highlighted text, the copy function is disabled.
I have the same issue with both Acrobat Pro 11.0.1 and Reader 11.0.1.
Ah, that's indeed a possibility - that the defect exists only on the Mac version.  I use, as you have noticed, Windows.
Feb 01, 2013 Feb 01, 2013
This is possible because you can put the cursor outside of the highlighted text. Now, try highlighting from somewhere in the middle of a paragraph, and using select tool, and try to select the higlighted line exactly. No more no less. You can't. You have to resort to selecting extra words along with the one in the highlighted area, and delete the unwanted afterwards. Freaking annoying.
Are you also on a Mac?  On Windows I have no problems doing exactly that:
Original paragraph
Select some text
Highlight it
Select the highlighted text
Copy it using Ctrl+C.
I suggest that Mac users experiencing this problem report it at https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Feb 02, 2013 Feb 02, 2013
im on windows7.. are you doing it with keyboard? i want to hightlight and select both using mouse.. it is fine with keyboard.. it's just doesn't seem to work with mouse..
EDIT: i just found it!! you have to be on READ MODE to be able to highlight and select easily using mouse.
Mar 11, 2013 Mar 11, 2013
@cryptdecrypt, wow, thanks for that solution! Yes, when you switch to Read Mode (ctrl+H), it's much easier to select Highlighted text.
Ugh, it is a total user experience fail to try to select text after it's already been highlighted by the Highlight Tool. I was previously using shift+click, but it was still difficult.
May 20, 2013 May 20, 2013
Agree completely that this is a user experience FAIL on Adobe's part.  Adobe developers - please think about it from the casual user's point of view.  Imagine the poor user clicking on every possible option trying to get this to work until they happen to stumble onto the fact that they have to be in "Read Mode" for this to work (and WTF is "Read Mode" anyway?).  Users shouldn't have to search the forums to figure out how to make something as simple as copy and paste to work, just because they have highlighted some text.
Jun 03, 2015 Jun 03, 2015
I wholeheartedly agree. Adobe's UI for any of their software is a total disaster. It is nearly 100% non-intuitive. You have to comb the menus or Google almost anything you want to do. And the solution is almost always a kludge like this one. If SHIFT worked properly, that would be OK, but it doesn't.
Oct 19, 2014 Oct 19, 2014
thank you SO SO SO much, you just made my life a  jazillion times easier!
Now way! This actually works. I never knew what 'Read Mode' was for and still don't. Why would anyone need or want a separate read mode? I can read just as easily in normal mode, thank you. And why should I have to toggle read mode on/off just to be able to select and copy text from a highlighted section? Just one more Adobe annoyance IMO. But thanks for finding this and pointing it out.
On OS X the shortcut to toggle Read Mode ON/OFF is:
    Ctrl-CMD-H
On 'Doze it's:
    Ctrl-H
Sep 26, 2013 Sep 26, 2013
This function is horrible. the problem is not just we can't copy and paste but have to click several times to get it. for every extra click we make, we lose our time. there should be a short key while our right hand on mouse and left hand on keyboard.
Also can we have an option to copy all or print all highlighted text for all pages or a range of pages. This would save a great amount of time.
